E39 Large EVAP leak - BMW Forum - BimmerWerkz.com
Old 01-16-2010, 08:53 AM   #1 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Biggaz is on a distinguished road
E39 Large EVAP leak
Ive got a large evap leak on my 1997 E39 535i... Any idea where the best place is to start looking for this ?
Biggaz is offline   Reply With Quote
Old 01-16-2010, 10:20 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Is it a little leak or major, is the CE light on? there are two possibilities either the fuel cap or the charcoal canister, please be aware I'm only going from passed experience, do you have any diagnostic codes?
Old 01-16-2010, 10:51 AM   #3 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Cheers for the reply Marti.
Well according to Autoenginuity it came up as - FE , EVAP Large Leak Detected
Old 01-16-2010, 11:04 AM   #4 (permalink)
marti5's Avatar
Okay...Its not the cap then, I would go for the charcoal canister, so do you have a light on?
Old 01-16-2010, 11:20 AM   #5 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
No light on.. That's something else I need to look at as when I turn ignition on I would of thought it would of done a self check like it does with ASC and airbag light but no check engine light
Old 01-16-2010, 11:26 AM   #6 (permalink)
marti5's Avatar
If there's no light on and the cars running A1 I wouldnt worry about it until the car starts playing up...you can change the canister if you wish.
Old 01-16-2010, 11:45 AM   #7 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Well the car runs fine up to 60mph over that and it runs like a pig.. Hence the reason I plugged it into my laptop and got the fault
Old 01-18-2010, 07:17 AM   #8 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Found out why my CE light doesnt come on, Got a Dead LED
Old 01-23-2010, 10:11 PM   #9 (permalink)
Poolman is on a distinguished road
As stated above the charcoal cannister is a good place to start--there is a vacuum pump thats attached to it--when it's called upon it runs a test by putting vacuum into the system--when the vacuum does not hold--then it throws a code. Now the vacuum pump is attached with a rubber gromet that can fail where it all seals up--you could have a leak there--thats a common spot to check. Go to real.com and enter the last 7 digits of your vin number and then check around for what I am referring to for your model--there will be diagrams of the parts and how they go together --along with part numbers --just in case you find what your looking for.
Poolman is offline   Reply With Quote
Old 01-29-2010, 01:21 PM   #10 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Purchased a Charcoal canister and will be fitting it this weekend... Will post if this cures my problem.
Old 01-29-2010, 03:27 PM   #11 (permalink)
Wishing you good luck!
Old 01-29-2010, 03:39 PM   #12 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Thanks mate
Old 01-31-2010, 12:47 PM   #13 (permalink)
Biggaz's Avatar
Car: 1997 BMW 535i
Changed the canister and i still have the problem
Old 01-31-2010, 03:17 PM   #14 (permalink)
Sorry to see, best of luck sorting it!
Old 01-31-2010, 05:18 PM   #15 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
I had this same issue when I first purchased my car, it turned out to be the fuel vapor expansion tank.......one of the nipples cracked off, causing a large evap. leak! My was located under the fuel filler tube, behind the rear passenger wheel well cover.....#1 in link below:
RealOEM.com BMW E39 535i EXP.TANK/ACTIVATED CARBON CONTAINER
jb
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
E39 oil leak. mikkey9289 5-Series (E12,E28, E34, E39, E60) 2 09-01-2009 10:18 PM
help Large leak in EVAP system Trouble shooting code P0455 MaClaud10 3-Series (E36) 3 03-02-2009 12:10 PM
EVAP capillary leak Hootie 3-Series (E46, E90) 3 10-20-2005 02:58 PM
Air Condition Leak - E39 The_Transporter 5-Series (E12,E28, E34, E39, E60) 3 02-28-2005 07:53 PM
C2 - EVAP large leak - Peak pherbolario 5-Series (E12,E28, E34, E39, E60) 1 02-23-2004 12:04 PM
