E39 Driver side rear door lock inoperable - BMW Forum - BimmerWerkz.com
Old 03-15-2007, 05:24 PM   #1 (permalink)
warsi is an unknown quantity at this point
Hi all,
I have a 1998 523iSE (UK) and driver side rear door lock doesn't work using central locking. I can lock/unlock it by push/pulling the lock knob though. It's when I lock/unlock the car then this one lock fails to lock or unlock.
I removed the casing but couldn't see the whole lock assembly due to it hidden behind the corner of metal frame. But I did notice a wire plug hanging on its own, I believe this plug needs to be plugged in there but can't see where without removing the whole lock assembly.
My question is: does this plug definitely needs to be plugged in there somewhere or there's something else wrong with the lock.
thanks,
warsi is offline   Reply With Quote
Old 03-20-2007, 06:20 PM   #2 (permalink)
tAgC's Avatar
Car: 97 540i
tAgC is on a distinguished road
Send a message via Skype™ to tAgC
Had the same problem on my rear driver side door, I had to replace the solenoid in the door as it went bad. Not that bad a job. The solenoid started making a kinda buzzing noise just before it went bad.
There are often loose plugs if you're car doesn't have certain features like lights in the doors etc.
Can you post a picture of the plug might help in identifying it?
tAgC is offline   Reply With Quote
Driver Side Window Won't Seal bren 3-Series (E36) 3 07-07-2004 11:13 AM
List of common e46 part numbers L337E46 3-Series (E46, E90) 0 06-07-2004 09:19 AM
electrical of licence plate, rear side lights javieruz 3-Series (E21, E30) 1 03-14-2004 08:08 PM
Another worthy competitor to the 3-series? AZ325Ci Other Rides 9 10-23-2003 06:08 PM
I NEED A LEFT (DRIVER) SIDE FOG LAMP FOR E36! nitrogass2000 Classifieds Sell & Buy 3 10-07-2003 10:49 AM
