E39 A/C Compressor noise - BMW Forum - BimmerWerkz.com
Old 04-02-2004, 04:56 AM   #1 (permalink)
NickC is an unknown quantity at this point
I have a '97 E39 saloon, it's a great car and gives me no real problems but I have had now, for about 2 years, a noise coming from the A/C compressor. I know it's this because if I turn off the A/C it stops.
It sounds like the bearing is sh@gged on the driveshaft of the comperssor yet I've had it checked out and it appears fine. The A/C works no problem and it's no issue other than it doesn't sound particularly impressive when sitting on tickover.
I tried spraying WD40 onto the pulley/shaft assembly and the noise went but then it's back a while later when things hot up under operation. Does anyone have any ideas as to what I could do to stop it other than the obvious replace the unit suggestion? Maybe something more viscous than WD40 that will stick and dampen the noise more?
NickC is offline   Reply With Quote
1998 E39 Low Revs Rough AndyN 5-Series (E12,E28, E34, E39, E60) 9 10-23-2005 02:39 PM
00 E39 M5 Question on engine sound Trevize M-Series (M1, M3, M5, M6) 3 09-29-2005 08:46 AM
Bavauto 3M Headlight, foglight Protector for E39 pamato Aftermarket Parts 0 09-29-2005 12:49 AM
e39 aircon question pawea 5-Series (E12,E28, E34, E39, E60) 1 09-25-2005 06:00 PM
FS: E39 & E53 Business CD mdimbler Audio/Miscellaneous Auto Parts 1 09-19-2005 10:43 AM
