E39 Brake Light Trouble - BMW Forum - BimmerWerkz.com
Old 12-01-2004, 01:05 AM   #1 (permalink)
Sporty540 is an unknown quantity at this point
My 'Check Brake Lights' message came on but lights still worked. But Left Brake Light was 'dark' in color, so I changed it. The new bulb immediately burned out. I did get the more expensive bulbs with the silver-colored base.
Second replacement also popped, and the 'Check Brake Lights' message has returned.
Ideas on how to check / clean / fix are appreciated. Thanks!
Sporty540 is offline   Reply With Quote
Old 12-01-2004, 07:25 AM   #2 (permalink)
njtech is an unknown quantity at this point
make sure you are using the 21W bulbs or you will still get the error message. as far as the bulb popping instantly...sounds like a dead short. I would start by pulling the tailight assembly and checking for any pinched/chafed wires.
njtech is offline   Reply With Quote
Brake Light Circuit Warning (again) Stamey 3-Series (E21, E30) 11 03-05-2005 07:05 PM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
