E39 Aux Fan - BMW Forum - BimmerWerkz.com
Old 04-02-2005, 08:33 AM   #1 (permalink)
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
On an E39 at idle is the electric fan suppost to turn on, if the engine begins to overheat, or is it only related to the A/C?
tacroteau is offline   Reply With Quote
Old 04-02-2005, 08:50 AM   #2 (permalink)
The Aux fan has two modes.
1. Always on with AC selected.
2. Turns on based on the temperature switch (values/) that screws into side of radiator. Some have two temperature settings (highand low) and others one.
Old 04-11-2005, 07:51 AM   #3 (permalink)
tacroteau's Avatar
So...is that a yes or no. Should the electric fan come on at any temp, with the a/c off?
[snapback]323720[/snapback]
Old 04-11-2005, 09:16 AM   #4 (permalink)
njtech is an unknown quantity at this point
Originally posted by tacroteau+Apr 11 2005, 06:51 AM--><div class='quotetop'>QUOTE(tacroteau @ Apr 11 2005, 06:51 AM)</div><div class='quotemain'>So...is that a yes or no. Should the electric fan come on at any temp, with the a/c off?
<!--QuoteBegin-Bear
[snapback]329990[/snapback]
[/b][/quote]
with the a/c off it will come on at a pre-determined temp.
njtech is offline   Reply With Quote
Old 04-13-2005, 10:42 AM   #5 (permalink)
tacroteau's Avatar
Ok, mine is not turning on at all any ideas?
Originally posted by njtech+Apr 11 2005, 10:16 AM--><div class='quotetop'>QUOTE(njtech @ Apr 11 2005, 10:16 AM)</div><div class='quotemain'>
Originally posted by tacroteau@Apr 11 2005, 06:51 AM
So...is that a yes or no.* Should the electric fan come on at any temp, with the a/c off?
<!--QuoteBegin-Bear
[snapback]330022[/snapback]
[/b][/quote]
Old 04-13-2005, 06:34 PM   #6 (permalink)
ben_t is an unknown quantity at this point
Check the fuse (number 25 I think) in the forward fuse box. Mine went recently. It uses a 30A fuse. If the fuse is OK then check the Aux Fuse Box (I think it is called). It is infront of the left strut. It contains the high speed and normal speed relays.
Hope this helps
ben_t is offline   Reply With Quote
Aux Fan Not Turning On mrclean 1,6,7,8 - Series and Mini Cooper 12 12-29-2005 09:27 AM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
e39 aircon question pawea 5-Series (E12,E28, E34, E39, E60) 1 09-25-2005 06:00 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
