used: The Air Con pusher fan (in front of the radiator) has stopped working. To check things before I replace it, as it is a costly item over £200 from BMW just for the part.
I think the fuses would be 9 and 20 but can someone please confirm this. I there any others I should check?
The seems to be a connector (4 cables two fairly thick) on the left hand side of the grill - radiator just next to the lights. I think this might be to the fan. If this is indeed the correct connector which two wire can I connect to a battery to see if the fan works and the problem lies else where?
: If the problem is the fan, what sort of a job is it to replace it, it would seem that a lot of the front of the car seems to be removed just to get to it.
Does anyone know where I could get a cheaper replacement
Thanks in advance for any help given
