E39 540i: M5 Kit - Fiberglass, How To Prep... - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 03-30-2005, 11:46 AM Thread Starter
///Matt's Avatar
Red face
My M5 body kit (front and rear bumpers) came in finally ...after 10 days of US customs impound. ghead
The result is pretty good i think, it is gray fiberglass (semi-smooth) on the outside and black smooth sealed on the inside. Obviously it is not prepped for painting yet, but i was wondering what i needed to do to prep it. Additionally, there are a few nicks in the surface. Is there an easy way to patch these.
Any help would be appreciated - THANKS!
(hopefully i will be able to attach some photos of it later....)
Regards,
///Matt is offline
post #2 of 4 (permalink) Old 03-30-2005, 11:50 AM
it depends on the type of primer your using. If it's a high build primer, you can sand the whole kit smooth with 180 - 220 grit and then clean it extremely well and prime it. If the nicks are small, The Bondo brand one part putty / glaze is extremely cheap and works extremely well. BE CAREFUL, though - fiberglass sands extremely fast and can wear uneven with varying pressure.
sp0rky is offline
post #3 of 4 (permalink) Old 03-30-2005, 11:51 AM
Originally posted by sp0rky@Mar 30 2005, 10:50 AM
it depends on the type of primer your using. If it's a high build primer, you can sand the whole kit smooth with 180 - 220 grit and then clean it extremely well and prime it. If the nicks are small, The Bondo brand one part putty / glaze is extremely cheap and works extremely well. BE CAREFUL, though - fiberglass sands extremely fast and can wear uneven with varying pressure. You could even just use a 600 - 800 grit to be on the safe side and just take longer doing it. If you know what a scratch from 180grit sand paper looks like.... Any surface imperfections that size the primer will fill in nicely.
[snapback]321553[/snapback]
sp0rky is offline
post #4 of 4 (permalink) Old 03-30-2005, 12:15 PM
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
I allways use glaze, its just so easy to fill those little nicks, rather then sanding them down and possibly digging yourself a wave. Just make shure you block it when sanding, this will keep it from looking like a crappy civic body kit with waves everywhere.
Good Luck
tacroteau is offline
E39 540i Manaul Tranny pamato Looking For 0 10-21-2005 10:30 AM
e39 540i Air Mass Sensor HardStep 5-Series (E12,E28, E34, E39, E60) 1 10-17-2005 11:15 PM
Looking to purchase e39 540i....Questions... DSkeet 5-Series (E12,E28, E34, E39, E60) 4 10-14-2005 07:28 AM
e39 540i alternator and battery question HardStep 5-Series (E12,E28, E34, E39, E60) 5 10-11-2005 01:18 PM
Vin Number skimmilk 5-Series (E12,E28, E34, E39, E60) 1 12-16-2004 06:07 PM
