Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 07-03-2008, 05:12 PM   #1 (permalink)
qq7
Photos: 0
qq7 is on a distinguished road
E39 530d M-Sport Engine Trouble
Hi,
I am hoping that someone may be able to shine some light on a problem I am having. I have a 2003 530d SE M-Sport Touring with approx 114k on the clock.
Driving the vehicle along the A14 I noticed that if I accelerated hard the engine would rev up to approx 2.5-3k and then flutter or may go to 3.5-4k and then flutter as if the rev limiter was cutting in. Placing the automatic gear box into Sport mode seemed to make it worse, presumably becuase it allowed to rev higher before changing up a gear. If you accelerated slowly there doesn't appear to be a problem and if the car is stationary in neutral it will rev up the dial without any problem. It is easily reproducible.
Connecting a diagnostics scanner, the software picked up a fault code of 1260 Delivery Pump Control system failure. Capturing live data seemes to show when the fluttering starts, the rail pressure drops from 1000 bar down to 500 and the pre injection fuel quantity drops to 0. Is this likely to be a fuel pump problem / fuel filter problem or ECU issue?
Any pointers or advice much appreciated.
Regards,
Chris.
qq7 is offline   Reply With Quote
Old 07-04-2008, 01:03 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 99 C43 AMG, 89 300SEL
Photos: 0
Send a message via Yahoo to darkhorse737 Send a message via Skype™ to darkhorse737
Lightbulb
check fuel filter first. then psi of fuel pump next.
if both prove good... the fuel pressure regulator will be the nxt line of suspect ;-)
ay sino caddi ububblaem? Heaven won't take me; and Hell just knows I'll take over...!
Old 08-16-2008, 08:58 AM   #3 (permalink)
Photos: 0
Last Exit is on a distinguished road
Hi Chris,
I have almost exactly the same problem with my 2002 e39 530d Sport Touring - though mine is fine on the flat but falters going uphill on motorways, limiting speed to 50mph which is pretty alarming.
Thinking it was the fuel lift pump, I replaced that, but to no avail. Reading the post on here 530D power problem - United Bimmer Community - BMW Forum perhaps that is not surprising - if it only works for the first 30 seconds.
My next suspect is the inline diesel pre supply pump, item 9 here RealOEM.COM * BMW E39 530d FUEL PIPE, DIESEL PUMP
darkhorse 737, when you say check the psi of the fuel pump, which fuel pump do you mean? (As far as I know there are at least two - the lift pump in the tank itself, another under the passenger seat, but there may be others?)
Have you managed to fix your car Chris, and if so what was the remedy?
All the best,
Fred
Last Exit is offline   Reply With Quote
vB code is On
530d E39 ( DDE ) light dirty diesels 5-Series (E12,E28, E34, E39, E60) 2 05-16-2008 05:26 AM
e39 530d smooth 5-Series (E12,E28, E34, E39, E60) 0 07-09-2006 11:51 AM
BMW 525D/530D Sport Mileage bbasra 5-Series (E12,E28, E34, E39, E60) 6 09-16-2005 02:17 AM
E39 528i Sport Engine Trouble qualitydobbers 5-Series (E12,E28, E34, E39, E60) 2 10-19-2004 07:34 AM
E60 530d Sport Release Dates iainparnell 5-Series (E12,E28, E34, E39, E60) 2 06-01-2004 04:43 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
