e39 528i passenger door double LOCK - BMW Forum - BimmerWerkz.com
Old 04-04-2012, 12:24 AM   #1 (permalink)
Car: e39 528i silver 150k miles
alex1020 is on a distinguished road
Unhappy e39 528i passenger door double LOCK
I have been looking for 3 weeks trying to unlock the front passenger door. on my 97 528i here is a list things i tried
- pull handle 2x
- pull handle 50x in a role
- use remote open/close many times
- turm key pass 90degrees
- hold outside door handle up and press remote open/close at the same time
- bump inside door by tweeter
- remove the air bag and move cable and wires
- I have some access to the actuator but cant see any problems/loos cable and or wires. (yes i did diconnected the batt.for this)
- I have Not broken off the actuator at this time..
Im will try to put 12v dc power directly to actuator wires just need to know wich wire and need a 12v dc power source (spare batt or charger) this weeken
My Wife Hate climming over the drive seat and made a F N rip in the seat today.
any other ideas.....
un-employed at this time so no Steelership for me on this problem,,,,
alex1020 is offline   Reply With Quote
Old 04-04-2012, 10:44 AM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
The actuator itself has micro switches in it which fail over time causing the door not to work. Start by checking all your fuses, as it's possible that a fuse tied into the central locking mechanism is blown. A door actuator is about $75-80.
Click HERE to see my E36 Blog
Old 04-04-2012, 12:20 PM   #3 (permalink)
door double lock
I check all the fuse's in the glove box and in the trunk.
Old 04-04-2012, 12:45 PM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Their shouldn't be any fuses in the trunk. I've never heard of that before. The fuse box is in the engine bay.
Old 04-04-2012, 01:00 PM   #5 (permalink)
passenger door double lock
I need to check the fuses under the cab/air filter right?
Old 04-04-2012, 01:47 PM   #6 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Maybe you were right. The two fuse boxes are in the glovebox and the trunk
BMW 535i E39 fusebox Location[1998] ? - Bimmerforums - The Ultimate BMW Forum
Check ALL of the fuses. Some fuses Mattie into the central locking without it being listed.
Old 04-09-2012, 11:48 AM   #7 (permalink)
Exclamation Need Help opening passenger door Lock
I took off the actuator yesterday but still cant open the passenger door.
There has to be some way or some thing that can trigger the release of the lock...
can some one please help...
Old 04-09-2012, 12:01 PM   #8 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
I've done it before with cars in the junk yard. Theirs a rod that connects the handle to the latch. You should be able to push up on the rod and it will pop it open.
Old 04-09-2012, 12:23 PM   #9 (permalink)
Door Double lock
Thanks, I'll look for the rod, and try it after work.. I'll take some picture if i get the door open and post them..
Old 04-09-2012, 01:51 PM   #10 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Sounds good. If you have any other questions let us know.
Old 04-16-2012, 04:02 PM   #11 (permalink)
After 2hr and 4 weekens I finaly got the Passenger door open. (pulling on the rod did not work on my 97 528i). I was able to push on the pins that connect to the actuator (i removed the actuator first) with a long flat head srw/driver. and it pop open. I took off the door panal, un-bolted the door lacth and cleaned the door lock mechanizm with wd-40 and re/lub all of the door lack mechanizm. I replace the same actuator on the door lacth mechanizm tested it many times before re-installing it, and so far so good. I would like to Thank Lord Vader for his advices and keeping me on track on this endevour..
Old 04-16-2012, 08:17 PM   #12 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Glad to hear it worked out for you.
Old 04-18-2012, 01:54 PM   #13 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Another Crime Solved, Vader
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 04-18-2012, 04:01 PM   #14 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Maybe I should have made my username Detective Vader instead?
When I wanted to learn how something worked on my car but didn't want to risk damaging it I just went to the local scrap yard. That's how I learned how the door locks and the hood latches work. It's the best way to get hands on learning without risk to your car.
Old 05-05-2012, 04:15 AM   #15 (permalink)
concreteman is on a distinguished road
how to open door on e39
My Wife's 2003 525 has locked the drivers door, won't open via any method. i have gone in through the airbag panel, removed the airbag and pryed off the actuator.
But now i am stuck and can't get the door latch to release. there is a plate with a hook in it that i can tilt forward, but it does nothing.
How did you or anyone else get the door to open.
concreteman is offline   Reply With Quote
Had to Slim Jim door Double Lock Reset Help Hybridarts 3-Series (E36) 9 12-13-2011 02:51 PM
Front passenger door lock da_bull 5-Series (E12,E28, E34, E39, E60) 2 05-20-2006 10:45 PM
Passenger door lock not working wulley1 3-Series (E36) 5 08-03-2004 12:01 PM
Passenger side door lock fahren_freude_3er 3-Series (E46, E90) 0 07-21-2004 01:00 PM
Double lock mole 3-Series (E36) 16 05-02-2004 02:18 AM
