E39 528i overheating - BMW Forum - BimmerWerkz.com
Old 01-06-2009, 01:33 PM   #1 (permalink)
foru2justnvmoi is on a distinguished road
Angry E39 528i overheating
Hi guys
I need ur help,
Ive got a 97 528i manual. It started to overheat about 4 months ago and was diagnosed as a thermostat, so i changed the thermostat, housing and vicscous. I made the mistake of not changing the waterpump, Now 3 months on the car runs lovely but the heating kicks in on passenger side first and then slowly makes its way to drivers side, now intermittently only when in slow traffic the car will overheat, and the tell tale sign is that the heating will cut out, but ive noticed if at standstill you rev the engine to 3,000 revs for around 30 seconds temp will come back down and heating will kick back in, apart fromn that the car drives fine, now noticed the other day after a 4 mile journey when i got home and opened the bonnet, that top hose was hot and bottom was cold, ive noticed that my ext pusher fan isnt kickin in even when the air cons on so i take it thats the temp switch on the side of the rad. If anyone know which pins to jumper or supply a live to in order to test it that would be great, I need your help on this one, could it be the waterpump or is it something else,
foru2justnvmoi is offline   Reply With Quote
Old 01-06-2009, 02:25 PM   #2 (permalink)
That seems like a typical need for a system bleed; I think there're air pockets in it.
Old 01-06-2009, 05:20 PM   #3 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
I agree with witeshark...... a bleed is necessary!
It really helps to have a friend lend a hand by sitting in the car revving the engine and keeping an eye on the temp gauge. Start off by removing the coolant reservoir cap and the plastic bleeder screw right next to it. Fill the coolant reservoir with a 50/50 mix of coolant and distilled water. Have your friend start the car, turn on the heater to full hot on the vent position and rev the engine to about 2500 RPM, if the temp gauge goes past the 12 o'clock position, shut the engine off, let it cool down and start over again. Watch the coolant reservoir, as the engine warms up the coolant level should drop, refill as the coolant is sucked out of the reservoir. Watch the bleeder screw hole also, when coolant with no air bubbles begins to overflow then you're almost done. It's a good idea to have some paper towels handy to mop up any overflow. Screw the bleeder screw back in (be careful to not break the plastic screw) and continue to rev the engine, you should see a continuous stream of coolant spraying in to the reservoir from the small hole at the top. Continue letting that spray in to the reservoir while your friend revs the engine for a couple of minutes, until the gauge hits the 12 o'clock mark, to ensure any remaining air is gone. If the heater is blowing hot air when you're revving the motor AND when the engine is at idle then your cooling system is properly bled. If your vents are blowing cool air at idle then you still have air in the system, try revving the engine more and/or squeeze the radiator hoses to help dislodge any trapped air. Once your system is fully bled, top off the reservoir and replace the cap. Check the coolant level in a day or two and top off as needed.
Old 01-06-2009, 09:23 PM   #4 (permalink)
Car: 1996 M3, 2006 X3
Carey Ward is on a distinguished road
Your fan should come on anytime your air conditioning is running. If it doesn't, chances are that the fan is bad. Some fans are two-speed and you can jumper for low or high. When I checked mine, neither one would work and I ordered a new fan from BAV Auto. Car runs cool now, even in the hottest Texas weather. Good luck.
Carey Ward is offline   Reply With Quote
Old 01-07-2009, 10:49 PM   #5 (permalink)
Car: E39 & E46
16valex is on a distinguished road
The pusher fan has very little or nothing to do with your car over heat. If bleeding don't work, you may have to change thermostat and water pump just to be safe.
BTW, you can direct inject 12V dc to Brown (negative) against other to to check for fan functions. My guess would be the resistor pack inside the fan ass'y, they are known for short live.
If you're familiar with electrical circuit, then you can by pass the resistor and check for fan motor, you can only do this only if the fan ass'y is removed.
16valex is offline   Reply With Quote
Old 01-26-2009, 11:47 PM   #6 (permalink)
Boy2k is on a distinguished road
Had the exact same problem in O6. I came up with a leak on the waterpump. Which I checked about a zillion time. The leak around the pump is hard to find because by the time you look under hood the fluids have already dried-up cause the enginge is hot. tighten the screws up and then see what what happens. And don't forget to bleed
Boy2k is offline   Reply With Quote
Old 03-23-2010, 09:18 PM   #7 (permalink)
J8291197 is on a distinguished road
Check your Radiator cap and make sure it is in good condition. I had the same problem but I had air pockets and a broken radiator cap.
J8291197 is offline   Reply With Quote
97 528i (e39) overheating????? BALKAN 5-Series (E12,E28, E34, E39, E60) 7 12-30-2006 07:56 PM
overheating e39... radiator or something else? help superdeadman 5-Series (E12,E28, E34, E39, E60) 7 03-19-2006 05:23 PM
98 528i Overheating!! What Else Could It Be blke39 5-Series (E12,E28, E34, E39, E60) 14 05-26-2005 12:29 PM
Overheating 1997 528I RoadKing 5-Series (E12,E28, E34, E39, E60) 8 08-10-2004 03:36 AM
E39 overheating? psubrizi 5-Series (E12,E28, E34, E39, E60) 5 08-09-2004 01:52 PM
