E39 525tds Glow Plug Relay Wiring - BMW Forum - BimmerWerkz.com
Old 06-17-2009, 06:27 AM   #1 (permalink)
manhuwa is on a distinguished road
Exclamation E39 525tds Glow Plug Relay Wiring
Does anyone know how to wire a resistor to the glow plug relay of a 5 series 1997 525 tds. It has the infamous hot starting problem, i bought a resistor of ebay to fool the ecu and kick start glow plugs and the fuel lift pump even when the engine is hot, i got confronted by a string of wires and two ecu`s when i opened the ECU compartment. can anybody help? or is there any other trusted way of curing the hot start problem, whereby if the engine is warm cranking is required to start the car?
manhuwa is offline   Reply With Quote
Old 06-17-2009, 09:18 AM   #2 (permalink)
I would consider a test of the main fuel pump(s).
Old 06-17-2009, 12:10 PM   #3 (permalink)
MADDOUG is on a distinguished road
Diesel Hot Starting Fault P38 - Land Rover Zone Not quite sure but this link from an ebay ad for range rover hot start fix (they also had the m51 Bmw engine) covers a bit of the wiring.
On my e34 tds I have read that a live can be connected to the original pump live so the pump can be run by flicking a switch on a hot engine,but this will also cycle the glow plugs as well whilst the pump has power.
MADDOUG is offline   Reply With Quote
Old 06-17-2009, 01:13 PM   #4 (permalink)
Maddoug
thanks for replying. i bought the resistor from the same guys on ebay who sell it claiming it works on bmw`s however the pictures they have of bmw ae very small and have not much details, as you know the bmw ecu is notorius for plenty wiring. i contacted them back and gave them pictures of my ecu plug , but they could point me to the right wire, i need an earth wire, glow plug relay heater wire and tempreture sender wire to connect the device i bought off that site *Diesel Hot Starting Fault P38* -
1996 E39 525TDS Torque problem georgedevries 5-Series (E12,E28, E34, E39, E60) 2 05-01-2009 02:05 PM
glow plug relay tarlac 5-Series (E12,E28, E34, E39, E60) 11 12-29-2008 01:25 PM
Advise On Rpm On Bmw 525tds E39 MvdB 5-Series (E12,E28, E34, E39, E60) 5 11-05-2005 06:17 AM
E39 Tds Glow Plugs Not Warming Up hanif001 5-Series (E12,E28, E34, E39, E60) 2 06-27-2005 02:39 PM
Cd-changer On Bmw 525tds E39 MvdB 5-Series (E12,E28, E34, E39, E60) 1 02-09-2005 10:18 AM
