E34 Radiator Problem- Help - BMW Forum - BimmerWerkz.com
Old 11-22-2004, 10:55 AM   #1 (permalink)
johnbmw is an unknown quantity at this point
Hello everyone...
I have an E34 with a radiator problem, it spills all the antifreeze from under the radiator. but everytime I pour more anti-freeze into it, it won't spill it untill after a certain time goes by, please help!!
John-
johnbmw is offline   Reply With Quote
Old 11-22-2004, 01:37 PM   #2 (permalink)
billB's Avatar
When engine gets hot it tends to build some pressure in your cooling system; as such you notice the leak after this build up. A pro may perform a pressure test on the system and decides if you need a new rad. Good luck
Old 11-22-2004, 02:05 PM   #3 (permalink)
Originally posted by johnbmw@Nov 22 2004, 10:55 AM
Hello everyone...
John-
[snapback]235265[/snapback]
Can you trace the leak area? I have had a few bad experiences woith the plastic drain plug BMW uses dopping coolant every now and then, but not a constant thing.
Old 11-22-2004, 02:11 PM   #4 (permalink)
Originally posted by Bear+Nov 22 2004, 02:05 PM--><div class='quotetop'>QUOTE(Bear @ Nov 22 2004, 02:05 PM)</div><div class='quotemain'><!--QuoteBegin-johnbmw@Nov 22 2004, 10:55 AM
Hello everyone...
John-
[snapback]235348[/snapback]
[/b][/quote]
The first time this happened, my mechanic said it was the pressure cap, we replaced it and now the leak is coming from under the radiator. Do u think it might be the a plastic drain under the radiator?
John-
Weird E34 540 tranny problem, help needed.. antose9 5-Series (E12,E28, E34, E39, E60) 8 11-08-2005 11:43 PM
E34 miss fire 98shaikh 5-Series (E12,E28, E34, E39, E60) 3 10-31-2005 10:32 AM
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
E34 - 18" Wheels swenpro 5-Series (E12,E28, E34, E39, E60) 22 10-24-2005 09:50 PM
Question regarding E34 front carpets m3driver97 5-Series (E12,E28, E34, E39, E60) 0 10-13-2005 02:32 PM
