e34 over heating problems - BMW Forum - BimmerWerkz.com
Old 05-13-2009, 02:26 PM   #1 (permalink)
e34fan is on a distinguished road
I recently purchased a 94 e34 with a blown headgasket. Turns out the head was cracked so i bought another one, plus a head gasket set. Even after replacing it, it still blows white smoke and overheats. Do you think it could be a warped maybe cracked block? Any input is very helpful.
e34fan is offline   Reply With Quote
Old 05-13-2009, 03:06 PM   #2 (permalink)
That would seem like a possibility.
Old 05-13-2009, 05:57 PM   #3 (permalink)
Car: Metamorphosis of the E34/92
Bimmermann is on a distinguished road
White smoke means that the cooling fluid somehow gets into the exhaust manifold from the block and out the pipes the steam goes. Take a looksy at the cooling fluid reservoir to see how low it is and if there are traces of oil. Look on the engine sides from above and below, try to determine if it leaks outside. In any event I'm sorry to say it seems like you've got a problem.
Bimmermann is offline   Reply With Quote
Old 05-15-2009, 02:52 AM   #4 (permalink)
Yes the coolant is low in the radiator after blowing out white smoke. Just so you know the block has over 200000 miles on it, but the head i bought is brand new. We replaced the head gasket, torqued the head to spec, and put in some no smoke and lucas oil. Yet it still smokes. The thing i can really think of is block warpage.
Old 05-16-2009, 10:24 PM   #5 (permalink)
Without a looksy to the physical is hard to guess exactly what, but the fact that it goes out at the exhaust tells me the cooling fluid reaches the exhaust manifold via the combustion chamber. Did you check the block to make sure it was not leaking from the galleries, before the head was changed? I looks to me the whole engine was shot.
Old 05-30-2009, 11:35 PM   #6 (permalink)
Ok thanks ill def. Check
Heating Problems scotty328i 3-Series (E36) 2 03-14-2007 01:01 PM
Heating Problems. lulul 3-Series (E36) 0 02-06-2005 08:45 AM
Odd Heating Problems... _1634_ 3-Series (E36) 13 01-18-2005 05:21 PM
over heating and accelerating problems Minolta 3-Series (E21, E30) 2 07-11-2004 03:14 AM
Heating Problems Portugal 3-Series (E36) 5 02-03-2004 07:12 PM
