E34 no heat help please - BMW Forum - BimmerWerkz.com
Old 01-20-2011, 12:56 PM   #1 (permalink)
WishiHadaM3 is on a distinguished road
Question E34 no heat help please
hey, i have a 91 525i, believe its the m50. a hose on my heater control valve/aux waterpump, think its also called something else also, came off due to brittle plastic with age i presume. anyways, i bought the entire assembly used off ebay, replaced it, and now i dont have any heat. when the "nipple" where the hose attached to auxiliary waterpump snapped, i was in the process of tearing apart my dash to install a radio, so i had disconnected the plugs for heat controls... blower works on all 4 settings, but just blows cold air... after i replaced the heater control valve/aux waterpump assembly ALSO had an overheating issue, believed to be air in the cooling system since i didnt close off hoses during replacement. i tried burping/purging air out of the system for a long time with no luck, so i finally came onto this site and found an answer. i took the upper radiator hose off and poured coolant directly in there until it came out the filler neck and bleeder screw, then replaced hose and it was fine, except now i dont have heat. i know this is a mess of a job, but any suggestions or possibilities would be a great help, im near milwaukee and its freeeeezing cold, thanks, cheers
WishiHadaM3 is offline   Reply With Quote
Old 01-21-2011, 03:35 AM   #2 (permalink)
42, The meaning of life
brettski's Avatar
Car: 2000 740iL Individual
Welcome to the Werkz.
Its good to know you've got some value from the site already. Are you sure that your control valve and aux pump are actually functioning? I'd start there and work your way around from that point.
Riding in style
A/C and Heat Help Heretic17 3-Series (E36) 4 07-28-2009 02:08 PM
No heat or air. Help! Help! Help! grandnationalcub 1,6,7,8 - Series and Mini Cooper 0 05-19-2009 08:04 PM
No Heat priscil9 New Members Check In 1 06-20-2008 11:41 PM
Heat? ghettozn 3-Series (E36) 3 08-02-2004 08:22 PM
No Heat cmoore 3-Series (E36) 1 03-10-2004 02:41 AM
