Hi, the previous owner of my 520i installed black leather interior from a M5 1994.
As you might know, the passenger seat does not have a memory function and is easy to bypass, but the drivers seat he could'nt figure out.
I cant figure it out either, I understand that I have to split the original connector from my 520i, but I have no idea what has to go where.
I don't care if the memory function don't work, all I need is the adjustment to be functional.
I read that you can ground a wire to bypass the memory function, but I have given up.
Here are pictures of the connectors:
The one from the cars original harness:
This connector is just the same as mine, only I have one extra blue/white wire I think is for the background light.
The ones on the seat:
I have figured out that the small connector is for the heat.
Appriciate all suggestions, thanks !
