E34 Key Initialization Block with a difference!! - BMW Forum - BimmerWerkz.com
Old 10-19-2010, 08:17 AM   #1 (permalink)
1cut808's Avatar
Car: 1995 BMW 530i in Oxford Green
1cut808 is on a distinguished road
Hi all,
I've done a few searches here and haven't found the answer I'm after.
So, I've just fitted a new 3.0ltr V8 to my 530i which hasn't been running for about 2 years. The key was flat so I replaced the batteries and went through the key initialization sequence. Bear in mind I only have one key!
The initialization sequence was followed to the letter but has not worked. The owners manual says that the vehicle will need to be taken to the nearest BMW Service Centre as the system is probably locked?
Is there something I can do to get around or reset this?
I still get all ignition/dash lights etc, just no cranking (no power to the start solenoid) and I can't hear the fuel pump going.
Not sure if it's related or not but the Radio code is also not being accepted by the factory radio.
Help please???
Mitch
1cut808 is offline   Reply With Quote
Old 10-20-2010, 06:09 PM   #2 (permalink)
1cut808's Avatar
I just spoke to a mate of mine who did his apprenticeship for BMW back in the day and he said that it could possibly be the EWS itself... Hope not!
The other thing to try he said would be the Key Barrel 'ring antenna'...
I have a complete spare drivers door handle with barrel, ignition barrel, ring antenna, glove box barrel and keys.. However the keys differ slightly as they don't have the little infra red LED thing sticking out at the base of the key. I have tried to initialize one of these aswell which didn't work either??
Anyone got any other ideas?
Mitch
Old 10-21-2010, 08:25 AM   #3 (permalink)
1cut808's Avatar
It seems that I have partially fixed the issue... I now have the 530i running, however the central locking still does not work off of the key??
At least it runs and drives now after sitting for the best part of two years...
Cheers
Old 10-21-2010, 09:34 AM   #4 (permalink)
Well that's a start!
e34 Key initialization block modenaf1 5-Series (E12,E28, E34, E39, E60) 1 10-15-2010 01:34 AM
Need an Extra Key for my 94 E34 (Non-Chipped) Katmandu 5-Series (E12,E28, E34, E39, E60) 4 11-09-2009 02:31 PM
e34 head swap to an e39 block? e34fan 5-Series (E12,E28, E34, E39, E60) 2 05-15-2009 02:44 AM
E34 Zf gear box swap plug difference beelzebubs FAQ's and DIY's 0 06-03-2008 08:42 AM
325i Key Initialization/programming swall1965 3-Series (E46, E90) 8 12-04-2004 12:50 AM
