E34 High Engine Temps - Overheating - BMW Forum - BimmerWerkz.com
Old 06-01-2006, 12:51 PM   #1 (permalink)
Car: 1990 BMW 535i
MarylandTim is on a distinguished road
Send a message via Yahoo to MarylandTim
Hi all, I have a 1990 535i that has beening giving me some "coolant temperature" warnings. The gauge goes all the way up to the red. This only happens when I am idling for a long time in traffic. But when I start driving the temperature quickly (within 5 minutes) goes back to normal. Is this common? I don't want to overheat or damage my engine so is there something I can do preventative? Or is there something I do to stop it all together? Thanks in advance for your help.
Tim
E34 High Engine Temps - Overheating-bmw-535-21a.jpg   E34 High Engine Temps - Overheating-bmw-535-3a.jpg
MarylandTim is offline   Reply With Quote
Old 06-01-2006, 12:56 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Could be either the water pump or thermostat (most likely the T-stat stuck) when the car is in motion air rushing over the engine is cooling the engine, whereas when the car is stopped no air flow no cooling. Start with the Thermostat and water pump (mostly for good measure if it's never been changed). Good luck!!
Come see me at MySpace
Old 06-01-2006, 01:08 PM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
I'd also check the fan clutch.
Here's how to check that: http://www.bmwe34.net/e34main/trouble/overheating.htm
Old 06-01-2006, 01:43 PM   #4 (permalink)
cnn
cnn is on a distinguished road
Suspect fan Clutch
Tim
The fact that it is normal at cruising means the fan clutch is not keeping up at rest (idle).
I just did the whole cooling system in my E39 and posted it here:
http://bimmerboard.com/forums/posts/199986
The trick for removing fan clutch is there.
Every 80-100K, consider replacing:
- thermostat
- fan clutch, fan blades
- radiator
- hoses
- water pump (use HEPU brand if you can find it)
cn
cnn is offline   Reply With Quote
Old 06-01-2006, 05:58 PM   #5 (permalink)
325isBaby's Avatar
Car: 2005 330xi
AH, but I have had a non-circulating water pump do the exact same thing as well as a stuck closed T-stat...so don't over look!
Old 06-02-2006, 11:31 AM   #6 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
From http://www.bmwe34.net/e34main/trouble/overheating.htm
How to test the fan clutch:
Sorry guys, the newspaper test is not reliable. If the thermostat doesn't work or is slow moving, the fan clutch will fail the newspaper test and will spin freely don't even bother explaining how it is done as it is dangerous.
What you should do:
1) make sure that the thermostat is working!
2) when the car is cold, the fan clutch should turn with a small resistance and not spin freely.
3) Let the car idling and the hood not closed but down. After 5-10 min, the temperature will rise at the 1/2 mark, check that the fan is blowing a LOT of air inside the engine compartment and increase in noise level, no need to put your hands, you will feel it. If when the temperature hits the 3/4 mark, the fan is not blowing a lot of air, that means that: either the thermostat is not working or slow, or the fan clutch is bad.
Oh, damn you torque. I just looked up and saw you posted the link already...
d3ity is offline   Reply With Quote
Old 06-05-2006, 09:48 PM   #7 (permalink)
Car: 1990 BMW 535i
Thanks everybody for your help. I think it's the thermostat. I gotta take it to the dealer since I don't know how to replace it myself. I'm keeping my fingers crossed that they don't say it's like $400 or something ridiculous.
Old 06-06-2006, 06:10 PM   #8 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Good luck and let us know
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
525i - Engine surging - high RPM ron 5-Series (E12,E28, E34, E39, E60) 1 03-04-2004 07:14 PM
Audi A3 1.6 FSI AZ325Ci Other Rides 2 09-06-2003 01:25 AM
