E34 Front end shaking, new HD bushes installed - BMW Forum - BimmerWerkz.com
Old 03-13-2009, 08:28 PM   #1 (permalink)
EnginE34's Avatar
Car: 1993 E34 525 M50
EnginE34 is on a distinguished road
Hey people,
I have a BMW E34 525 M50 engine, has really bad font end shaking, just put HD thrust arm bushes and the control arm seems like its in pretty good nick. The dics are fine wheels have no buckle and have been balanced about 5 times in the last 2 months now, new tyres, only problem with the car seems to be the shockers are gone and needs new ones.
The shaking starts from about 70 and gets worse and worse, till its unbearable at about 100 and than gets more rapid as I increase speed.
Anyone out there had similar problem where bushes were good but still shaking around, I have tried about 5 mechanics and read 20 million forums and can't find anything, anyone out there got any ideas.
Much appreciated.
EnginE34 is offline   Reply With Quote
Old 03-13-2009, 08:38 PM   #2 (permalink)
Things to check: It may just be bad tires. Are wheels balanced?
Old 03-13-2009, 08:42 PM   #3 (permalink)
EnginE34's Avatar
Yeh wheels are balancing perfect, brothers got the same car put them on that and perfect, tyres a new Good Year Eagles
Old 03-13-2009, 09:11 PM   #4 (permalink)
You might wanna check the lower control arms and bushings.
Old 03-15-2009, 01:02 AM   #5 (permalink)
EnginE34's Avatar
Had a look at the lower control arm seems pretty good, but will be pulling that out next weekend hpoefully, just more or less wanted to know if there are any other issues that actually may occur apart from the usual bushings and wheels, cause I have eliminated most of that.
Old 03-15-2009, 01:06 AM   #6 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
do you feel it in the steeringwheel? could be your driveshaft outta balance
1992 318i Coupe parts car
I am Captain Obvious
Old 04-03-2009, 10:41 PM   #7 (permalink)
EnginE34's Avatar
Finally solved the issue, after 1600 bucks and about 3, 4 hours mucking around on the bushes and everything. Apparently, and I dont know why none of the mechanics or wheel shops could tell me, if you put E39 wheels on a E34 it needs hub rings, there is a slight difference in the inside corner of the wheel where it touches the hub, which needs to be filled, the problem was easy fixed for 20 bucks.
Good news though, got bilsteins shocks now and it drives fantastic abit harder than normal but fairly good, and got the eibach's coming now as well.
99 528i Wheel and Front End Shaking Problem thedude2470 5-Series (E12,E28, E34, E39, E60) 10 12-18-2010 07:51 PM
E36 coupe front end and four door front end... saylee 3-Series (E36) 6 01-19-2009 04:00 PM
5251 front end shaking ultrasport06 5-Series (E12,E28, E34, E39, E60) 6 08-21-2007 09:15 AM
1990 525i e34 vibration / shaking at around 80km/h (50mph) stonedewok 5-Series (E12,E28, E34, E39, E60) 2 11-17-2005 03:12 AM
E34 Front-End Vates 5-Series (E12,E28, E34, E39, E60) 1 06-26-2004 03:08 PM
