E34 Exhaust Removal (stuck?) - BMW Forum - BimmerWerkz.com
Old 02-12-2005, 07:09 PM   #1 (permalink)
isosceles is an unknown quantity at this point
In an attempt to change my center support bearing and rubber on my '94 540, I've started by trying to remove the exhaust system.
I removed the 2 bolts per pipe, disconnected the O2 sensors, and disconnected the hanger/clamps by the back of the tranny.
Why can't I get the pipes to separate from the manifolds? I've had a big pry bar under there, soaked it down with PB Blaster, tried it hot and tried it cold and they STILL won't budge ghead
Any techniques you can share would be appreciated.
Mark
isosceles is offline   Reply With Quote
Old 02-13-2005, 12:05 AM   #2 (permalink)
numberthree_ is an unknown quantity at this point
Send a message via AIM to numberthree_
are you sure its only 2 bolts per pipe??
<img src='http://memimage.cardomain.net/member_images/3/web/699000-699999/699782_49.jpg' border='0' alt='user posted image' /><img src='http://logo.cafepress.com/5/2952.592505.gif' border='0' alt='user posted image' />
<span style='color:Green'>...no matter how slow your BMW is, at the end of the day, you still drive a BMW</span> :redspotda
<span style='color:Green'>Member of the Spririted Driver Club.</span>
numberthree_ is offline   Reply With Quote
Old 02-13-2005, 02:04 AM   #3 (permalink)
Arjan e28 535i is an unknown quantity at this point
Did you remove the two small brackets (halfway between the O2 sensors and manifolds) as well?
Arjan e28 535i is offline   Reply With Quote
Old 02-13-2005, 05:53 AM   #4 (permalink)
[snapback]290877[/snapback]
Number3, that's all I see per pipe, and all that shows in the Bently manual. It has a rounded diamond shaped flange with bolt holes at the 2 points, unlike a triangular 3 bolt flange. I'd double check though.
Arjan, I might have missed those. used I removed the clamp/hangers near the rear of the tranny, but those are close. Now that I examine the diagram a little closer, I see the ones you are referring to, and I don't remember taking those off.
Thank you both for your suggestions!
Edit: Turns out I had all the brackets removed. I went out this morning and the left side had come down and the right side needed a little more persuading with a breaker bar. Now I need to get some bigger combo wrenches. Those bolts at the front of the driveshaft are big. At least my diagnosis was correct. The metal bracket that surrounds the rubber for the center support is broken. My Bently manual says to drop the whole drive shaft to replace it. If anyone knows of a shortcut, I'd welcome the info.
Need Help!1987 325es: Exhaust Leak/runscrappy pettas 3-Series (E21, E30) 12 12-11-2004 05:12 AM
If Your Looking For A New Exhaust For A 328i... RDM3 Classifieds Sell & Buy 0 11-23-2004 04:07 PM
Fs Fk Automotive Exhaust For E36 328i New RDM3 Classifieds Sell & Buy 0 11-23-2004 04:06 PM
Ticketed for loud exhaust in California? Silver4evr Bimmer Talk/Motorsports Talk 0 06-23-2004 04:03 PM
