E34 crankshaft sensor - BMW Forum - BimmerWerkz.com
Old 06-09-2011, 01:53 PM   #1 (permalink)
Car: 92 BMW 525i
crowegreg is on a distinguished road
Is the crankshaft sensor located towards the top or the bottom of the engine? I figured that since it's related to the crankshaft, it would be located towards the bottom, but I can't see anything that resembles it. I see the sensor on the top part of the engine, but I'm assuming that is the camshaft sensor. Any assistance would be greatly appreciated!!
crowegreg is offline   Reply With Quote
Old 06-09-2011, 02:20 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Here you go...
RealOEM.com BMW E34 525i TIMING CASE
Part 9 is the sensor...
DAZ
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 06-09-2011, 02:33 PM   #3 (permalink)
Car: 92 BMW 525i
Thanks for the diagram. Do I have to remove something in order to view this item? I'm assuming that the sensor I'm looking for is not located on top of the engine?
Old 06-09-2011, 02:39 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Probably the fan for easier access...
You will know it when you see it compared with the diagram mate... It is more central than anything as it acts as cam sensor too lol
Good luck Fella...
DAZ
Eso es todo!
BMW Part Market
New Member ?
Old 06-10-2011, 09:43 AM   #5 (permalink)
Penngwyne's Avatar
Car: E34 525i 1989/03
Penngwyne is on a distinguished road
Picture is worth etc
Its the metal cylinder at about the 10 o'clock position on the toothed disk behind the crankshaft pulley
This one has a cable tie on it (but it isn't there now)
It's easier to see with all the belts, hoses and pulleys out of the way
Probably easier to get at from underneath? Taking off the plastic pan under the front?
or maybe not?
My daily is a Mitsubishi HSGR (but I wouldn't mind an e34 525i)
Penngwyne is offline   Reply With Quote
Old 06-13-2011, 07:09 AM   #6 (permalink)
Penngwyne's Avatar
And this should be the whole story
Untitled Document
Go contents select 12 - 14 - 155
The connector is under the wiring box on the LHS and has a wire clip you need to press in to remove it
Old 06-26-2011, 08:15 AM   #7 (permalink)
Penngwyne's Avatar
Any success with this?
BMW E34 Crankshaft position sensor Rolandos147 5-Series (E12,E28, E34, E39, E60) 7 03-13-2012 10:59 AM
Crankshaft position sensor broke!!! drews1987m20 3-Series (E21, E30) 16 09-27-2009 01:24 PM
Crankshaft positioning sensor not aligned aubreytp 3-Series (E36) 1 02-25-2009 09:34 AM
crankshaft position sensor wabenzy 5-Series (E12,E28, E34, E39, E60) 2 12-18-2008 01:11 PM
M44 Crankshaft dclaw Classifieds Sell & Buy 0 02-14-2005 04:17 AM
