e34 Climate Control - BMW Forum - BimmerWerkz.com
Old 05-22-2004, 06:16 PM   #1 (permalink)
Aladdin is an unknown quantity at this point
My e34 A/C works fine but only if it's blowing out the console vents. Anything else, (floor or defrost) blows out air that is super heated. I don't understand this. Suppose even in non A/C mode, shouldn't I be able to get outside air vented in that is only mildly warmed? In the winter, I'm using the defroster and then venting the sunroof to let out some of the heat, no matter what the temperature dials are set at. I can never get cold air at the floor level.
Also, in between the two center console vents, there is a dial that has red on one end and blue on the other ... hot vs. cold? I don't think it works or I'm using it wrong, how is it supposed to work?
Is this a common problem?
Aladdin is offline   Reply With Quote
Old 05-23-2004, 09:12 PM   #2 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
yes, common problem.
Go refill your refridgerant
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 27 05-03-2010 09:59 AM
Wacky Climate Control moe19x 3-Series (E36) 7 10-22-2005 11:38 AM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 09:09 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
