__________________ <span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
so you are looking for a way to turn a regular 535i in to this monster?
__________________ Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
The project will probably happen quite a bit down the road, but I'm looking at getting a pair of small turbos ball bearing Garrett T25s would work fine, and boosting about 12.5 to 13PSI max. That would be equivalent (but infinitely more efficient) to the Dinan stage 3 supercharger which produces about 426hp and 398lbs/ft of torque. I plan on running each turbo through it's own individual intercooler (probably going to try to Ebay ICs from a 300zxTT, it uses individual ICs) and back into a main intake manifold, most likely a modified version of the stock one. I'm also going to see if I can possibly find a performance engine rebuild kit so I can have a fully balanced motor. I'm also planning on Dinan exhaust and Dinan hot cams (unless anybody else makes good quality E34 540i parts) I'm still trying to figure out how to rig up Air Mass Meters to run in parallel. Anybody who knows about this, I would appreciate it.
I mostly just want the Alpina body for it's beauty. I can promise that the car will go much harder than any B10.
Addicted to Speed Since 1997 Founding member of the GreenDragon Poo Flingers Club
check on the Nikasil in the E34 M60/2 engine before tossing high power mods.
an updated engine with Alusil should be installed
