E34 Alarm Trouble - BMW Forum - BimmerWerkz.com
Old 10-31-2004, 09:23 AM   #1 (permalink)
c21no1 is an unknown quantity at this point
Send a message via AIM to c21no1
I recently bought a 92 525i, the other day the battery went dead, when I replaced it, the alarm went off and I don't know how to turn it off, if I close the doors it will stop after a few seconds, but as soon as I open one, it goes off again. I don't have a remote for it and when I try to start it, there is nothing. I would really appreciate any help!!
c21no1 is offline   Reply With Quote
Old 10-31-2004, 09:37 AM   #2 (permalink)
Luvring is an unknown quantity at this point
[snapback]221622[/snapback]
I had a similiar problem. Sounds like the alarm needs to be reset. Try removing the fuse for at least 48 hours or so. Then replace. Hopefullly it will work. It did for me and I haven't had any alarm problems since. I have a 97 540i. Good luck
Luvring is offline   Reply With Quote
Old 10-31-2004, 10:26 AM   #3 (permalink)
billB's Avatar
c21no1
On my car I can insert the key either in the trunk or driver side key slot and turn it (turn all the way till the key becomes horizontal) clock wise to engane the alarm and counter clock to disengage it. Assuming you alarm is factory;Can you do that on yours? If so go to your car and try it. This will reset it.
good luck
billb
Old 10-31-2004, 10:39 AM   #4 (permalink)
I tried the key in both the trunk and the drivers door, neither worked. I was going to try the fuse, but I can't find it. Even when I unplug the module under the rear seat, the alarm continues to go off. This is very depressing, I've only had the car for a week. I appreciate all your input very much!
Old 10-31-2004, 05:11 PM   #5 (permalink)
When I disconnect the battery and re-connect it it will immediately set off the alarm, is there any other way to turn it off or disconnect it? It won't start, and I really need the car.
Old 11-01-2004, 09:15 AM   #6 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
unplug the alarm unit. it's located under the rear seat.
do a search under this forum. They're many posts on this subject. I have even listed the fuse number and location. If you need more help let me know.
LOS
Old 11-01-2004, 09:17 AM   #7 (permalink)
I've done that and tried most things, nothing seems to work, I'd be happy just removing the system, I can install an aftermarket one later. Is there anything I can disconnect to get the car started?
Thanks
Dan
Old 11-01-2004, 09:19 AM   #8 (permalink)
LOS
LOS's Avatar
Did you located the alarm unit? Just unplug it for now. The car will start.
Old 11-01-2004, 09:24 AM   #9 (permalink)
LOS
LOS's Avatar
go to circlebmw.com for additional information on the alarm unit
Click on service dept, then tech tips
Also, do a search. Just click "my assistant" and type alarm as the subject.
Old 11-01-2004, 09:28 AM   #10 (permalink)
I did unplug it, but the lights still flash and the car still will not start? Seems strange to me. Here is exactly what transpired, The battery went bad, the car started with a jump. I then replaced the battery, that is when all the trouble started. The previous owner said something about pressing the number one on the dash computer to turn it off, which doesn't work. So here I am. I do hear some sort of relay clicking on and off under the drivers dash speaker. I am totally lost. I can't believe unplugging the control box didn't turn it off!
Old 11-01-2004, 09:38 AM   #11 (permalink)
LOS
LOS's Avatar
ok... I the alarm unit is about 6 x 4 x 1" thick, black in color. They're two locations that the unit could be in. It's either under the rear seat or in the hood (engine compartment)
The fuse number is 18 and/or 21 located in the glove box compartment. There was another member "quablos.." who found the unit in the engine compartment under neath the fuse box (left hand side).
If you need addtional help send me an private email with your number and i'll call you right now.
LOS
Old 11-01-2004, 09:49 AM   #12 (permalink)
LOS
LOS's Avatar
Ooops , I read that post and the unit IS NOT in the engine compartment. He found it under the rear seat well hidden under the fuse box...
Sorry for the confusion on my part.
LOS
Old 11-02-2004, 10:46 AM   #13 (permalink)
I figured it out! There was a push button and a switch way under the dash on the drivers side that I had to flip the toggle, hold down the button and start the car and it reset! I'm guessing this must be some kind of aftermarket alarm? If so, I wonder why the factory control box is still plugged in also? Anyways, thanks for the help!
Old 11-02-2004, 11:56 AM   #14 (permalink)
LOS
LOS's Avatar
Sounds like an aftermarket system... Good job on figuring out!
LOS
Old 11-02-2004, 11:58 AM   #15 (permalink)
Thanks, I'm thinking about a new keyless entry/alarm/remote start for it, do you think I should try to do it myself or have it done?
E36 328 Factory Alarm Problems Dayvg 3-Series (E36) 13 06-16-2005 07:24 AM
Bmw Alarm Vs. Viper Alarm dugies25 Audio and Electronics 8 03-24-2005 03:48 PM
Factory Fitted Alarm smoker 3-Series (E36) 5 03-08-2004 11:40 AM
Funny thing about factory alarm mostwired 3-Series (E36) 9 01-26-2004 02:16 PM
ALARM DHW BMW328I 3-Series (E46, E90) 9 08-08-2003 03:43 PM
