e34 540i 1994 fuel consumption gauge.. - BMW Forum - BimmerWerkz.com
Old 02-01-2009, 06:04 AM   #1 (permalink)
longdom's Avatar
Car: 1994 e34 540i
longdom is on a distinguished road
hi to all,
does anyone know why my fuel consumption gauge, the half moon shaped one under tacho, all of a sudden has gone crazy???
when car is off, its at 0
when driving it moves around, but doesnt really look like its stable.
when im idling, its at maximum fuel consumption, actually so high, i cant see the needle..and have noticed on obc, that my consumption levels have risen from 11.5-12.6 average, to 15 and climbing still...(thats lt/100km).
anyone have any ideas?????
thanks again........
longdom is offline   Reply With Quote
Old 02-02-2009, 12:03 AM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
That's how it works.
1. When it's off, you're using no fuel ...
2. It's by no means accurate; it's pretty much dependent on throttle inputs to get it's estimation.
3. Think about it. You're idling, therefore fuel is being used, yet you're getting no movement. You could use up a 1000 liters and not move at all, so yes, the consumption average will climb on the OBC, just like it does mathematically if you were to calculate it yourself.
4. You're being paranoid.
Old 02-02-2009, 02:04 AM   #3 (permalink)
longdom's Avatar
Car: 1994 e34 540i
ok..so why was it different for the first month that i drove the car????
and now its been a week, that its like this???
the fuel gauge was always on 0 when idling, and would move with acceleration, obviously, and consumption was 11-12.8lt/100km, i have been following it, now all is different...explain that...
Old 02-02-2009, 02:05 AM   #4 (permalink)
longdom's Avatar
Car: 1994 e34 540i
did you read my thread?? by the way...
Old 02-02-2009, 10:47 AM   #5 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Then it was broken before. The consumption can't be 0 l/100km if the engine is running and you're not moving. Your consumption is actually infinite, that's why you can't see the needle.
Old 02-02-2009, 12:11 PM   #6 (permalink)
MADDOUG is on a distinguished road
If it does not look stable,it should sweep back and forth slowly on gentle throttle and nip back sharpish to near zero when cars given some,then check under the drivers dash knee high panel,on my 94 tds the sensor that works it lives there,mine has a vacuum connection to it (diesel turbo) plus the multiplug,yours may have a vacuum connection and maybe dodgy engine vacuum or leaking pipe is confusing it.As for tickover it goes off and no throttle at speed in my autobox equipped car it will show about 20mpg at 80mph simply because the box is in 5th gear lock up mode,other gears coasting the engine drops to tickover and it goes off with needle dropping back past zero to its home position.Driving at constant speed the needle should stay still,slight on or off throttle will get it to move either way,and a boot full gets it to move quickly to 15/20mpg,yours may well move quicker as yours is not capable of near 50mpg.
MADDOUG is offline   Reply With Quote
Old 02-15-2009, 08:35 AM   #7 (permalink)
longdom's Avatar
Car: 1994 e34 540i
problem still not resolved...
i will look under dash and let you know what i find.
but idling, i notice on obc that consumption reaches and passes 40lt/100km, and gauge is higher than maximum, it used to sit on 0 when idling, then i must of touched something under dash, when i tried to get to brake light switch, since then its gone crazy..
so you say under dash, can you describe exactly what im looking for, cause i think that could be the problem.
thanks..
Old 02-15-2009, 08:52 AM   #8 (permalink)
When you take the panel out that fits in front of your knees,the padded one,on the back should be a small box about half the size of a cigarette packet,this has a multi plug that has around about 7/8 thin wires going in it,and the vacuum pipe goes into one side of it.When I first see this on my car I thought it was the buzzer or gong for the 'lights on alarm' and then I clocked the vacuum pipe and the multiplug,the multi plug wiring is traceable back to the throttle pedal potentiometer so if yours is not on the back of the panel then follow the wiring from the throttle pedal to find it.
Old 02-15-2009, 11:31 AM   #9 (permalink)
MeanM50's Avatar
Car: 1992 525i NV M50...lightly mod'd
MeanM50 is on a distinguished road
If your ECO gauge is not 'working right', I would suspect that the gauge is correct and there is a problem elsewhere on the car. It's true that these cars figure MPG as an average....so when you are idling, you SHOULD register a 0 MPG....because you are using fuel but not accumulating milage. This is why the OBC MPG and consumption figures are incorrect.
If anything, I would say that the ECO gauge was incorrect for the first month, and is now correct and functioning properly.
MeanM50 is offline   Reply With Quote
Old 02-15-2009, 07:01 PM   #10 (permalink)
Car: 1994 e34 525
coolvegase34 is an unknown quantity at this point
I have a quick suggestion. Fill up your tank with gas. Reset your trip odometer. Drive until you have used 3/4 of a tank of gas. Fill it up. See how many miles you drove via your trip odometer. Divide the miles by the gallons used and that is your gas mileage. This is how we did it before we had fancy computers. These cars get horrible gas mileage, I don't care what year or model it is. That floating mpg indicator is so inaccurate. They just put it there so it looks cool. But, guess what? You don't by a bmw because you care about gas mileage. Drive it and enjoy. If you want 30mpg, buy a japanese econobox. That is what I drive when gas costs $4.55 per gallon. My Bmw sits in the garage.
coolvegase34 is offline   Reply With Quote
Old 02-17-2009, 05:59 PM   #11 (permalink)
MeanM50's Avatar
A 2.5 liter six that gets 25MPG? Yeah....that's horrible. Just as horrible as my wife's Honda Accord.....only my BMW has more power, is quieter, and rides nicer.
Old 02-17-2009, 06:41 PM   #12 (permalink)
JesterMX6 is on a distinguished road
my current m50 nor my mom's that she had for years never did better than 20mpg in town
BMW 535i - A Fillet on Wheels, Rare but Well Done
88 Mazda MX-6 GT :: 78 Suzuki GS550E :: 88 Mazda 323 GTX :: 90 BMW 535i/5 :: 87 Mazda MX-7 GTII
JesterMX6 is offline   Reply With Quote
Old 02-23-2009, 12:41 AM   #13 (permalink)
longdom's Avatar
Car: 1994 e34 540i
well looked where you told me to look, MADDOUG, all i have after i remove the panel is the gong, with 2 sets of wires coming out of it, and the a/c tube that goes to feet...
im talking about drivers side, right hand drive bmw...nothing else behind panel thats knee height.
will look on throttle pedal next, to see if i can locate any wires...will let you know..
Old 02-23-2009, 04:26 AM   #14 (permalink)
longdom's Avatar
Car: 1994 e34 540i
found nothing, and no wires from throttle..
i give up..
anyone have photos or diagrams, as to where i can check if this gauge is working?
i have pulled the damn car apart 3 times and to no avail...
new owner of a nice e34 540i 1994 V8 longdom New Members Check In 3 03-18-2011 01:49 PM
1994 BMW 540i e34 vs. 1992 Mercedes 400E ThomasD3 5-Series (E12,E28, E34, E39, E60) 11 10-19-2010 03:41 PM
318' E36 Fuel Gauge And Temp Gauge Problems Help!! mrfunk 3-Series (E36) 7 04-28-2010 05:22 PM
Need Help 1994 E34 540i.... longdom 5-Series (E12,E28, E34, E39, E60) 27 11-08-2009 07:06 PM
Fuel consumption sp0rky 5-Series (E12,E28, E34, E39, E60) 0 10-12-2003 01:00 AM
