E34 530i - M60B30 --> M60B40 conversion. - BMW Forum - BimmerWerkz.com
Old 12-13-2011, 11:46 PM   #1 (permalink)
Vard66's Avatar
Car: 1993 530i V8 Touring
Vard66 is on a distinguished road
Send a message via MSN to Vard66
Probably should be in bed, rather than posting on here, but nevermind that.
I typed out some queries about the management just now, before realising that I might as well knock a whole thread up and get any questions I have regarding the conversion answered in one. I searched and found a few threads, but couldn't see great merit in bumping them up for my purpose rather than simply creating a new one.
Anyway, I'm waffling.
From my limited research, it seems to me that in order to swap the M60B30 out of my '93 530i and slot in an M60B40, what I need to acquire is thus;
engine, inc all ancillaries, plus inlet manifold,
all sensors on the engine, plus I'm assuming lambdas if present,
management,
However, I have some questions.
First and simplest; is all that correct?
Secondly - in my window shopping on eBay, I've encountered a couple of ECUs for the E34 M60, yet quite a few of the adverts claim that their ECU will suit the whole range of M60 equipped cars - to my mind, unless it's self-adjusting like Rover's MEMS system, that can't be right. Surely the maps must be different between the displacements?
Thirdly, I'm lead to believe the downpipes used on the B30 application are suitable for the B40, so bolt off bolt on - correct?
Fourthly, I'm also lead to believe that for some peculiar reason, the B30 has a larger dia clutch than the B40, but either will fit. My search on here told me that either flywheel is good to use; but If I'm thinking to fit the clutch from the B30 (or whichever is the larger of the two diameter clutches), will I need to use the flywheel from the relevant engine, or does it not matter which?
Finally - is my list missing anything, be it critical or optional?
TIA
Vard66 is offline   Reply With Quote
Old 12-15-2011, 05:01 PM   #2 (permalink)
Alex SBY's Avatar
Car: 1993 E34 530i Touring manual
Alex SBY is on a distinguished road
Cheers for making this post - you've saved me the hassle!
Now, is this a ridiculous idea or doable? Any assistance would be greatly welcomed.
BMW:
1993 E34 530i Touring Manual
Rovers:
1990 820 RAT, 1992 216 GTi TC,
1993 827 "E-R17" Ex Buckingham Palace Sterling
1998 820 Vitesse Turbo Coupé
Jaaaaags:
1991 XJ40 3.2 XJ6, 1995 X300 4.0 Sov, 1997 X308 4.0 Sov LWB
Alex SBY is offline   Reply With Quote
Old 12-16-2011, 12:00 PM   #3 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Firstly, TB and Manifold would suffice at this time..
Secondly, the ECU is specific to the engine and will need "matching" (programming) to accept the engine, clocks and security !
Thirdly, quite possible.
Fourthly, you answered that... Match them !
Finally, pretty much identical units, just how they take fuel-mixture (ECU controlled if everything else is ok)...
Not a definative answer as the same applies to BMW's straight sixes !!!
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 02-03-2012, 06:16 AM   #4 (permalink)
Vard66's Avatar
Possibly worth merging this thread with the thread about the car, Mods?
_____
Vard.
1994 Rover 820 Vitesse
1994 Rover 420 GSi Turbo
530i 540i conversion/ head replacement weldmachine 5-Series (E12,E28, E34, E39, E60) 2 04-13-2010 02:31 PM
M3 conversion zinger 3-Series (E36) 8 06-04-2006 07:14 AM
Need M60b40 MIKE325I 5-Series (E12,E28, E34, E39, E60) 0 10-19-2004 08:59 PM
M60B30 Block Question chochy 5-Series (E12,E28, E34, E39, E60) 4 07-20-2004 11:58 AM
MAF conversion? 1985bmw325e 3-Series (E21, E30) 7 03-10-2004 10:57 PM
