E34 525tds Auto Hot Starting & Stalling - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 09-13-2008, 08:54 AM Thread Starter
peterbrent is on a distinguished road
Unhappy E34 525tds Auto Hot Starting & Stalling
Hi,
I'm new to the forum, but have a problem if anyone can help.
I have a 1995 525tds auto which starts absolutely fine when cold, catches as soon as you turn the engine every time. However, when hot it takes a good 10 to 12 seconds of churning before it starts, again every time. Also, the engine has a habit of stalling when you engage drive or reverse, and also when changing from one to the other etc. This second problem can be averted by applying a little revs whilst engaging gears, but you shouldn't really have to do that. It idles at somewhere in the region of 600 to 650 rpms and I wonder whether this is a little slow for an auto diesel? If so, how do you speed this up, it doesn't seem to have a throttle cable as such as the car has cruise control fitted, so I am presuming it is all controlled electronically.
Back to the starting problem, one mechanic has suggested that this is a fuel pump problem, but that sounds as though it could be extremely expensive, therefor any help or advise would be greatly appreciated.
Many thanks in advance.
P.
peterbrent is offline
post #2 of 9 (permalink) Old 09-13-2008, 11:18 AM
Help from over the pond
marti5's Avatar
When was the last time you put any injector cleaner in ?
marti5 is offline
post #3 of 9 (permalink) Old 09-13-2008, 11:28 AM Thread Starter
Hi,
Only had the car a short while so not ever put any in myself.
Car is located in Spain, has 202,000km's on the clock and other than these couple of problems she seems a good car, drives well.
Ta.
post #4 of 9 (permalink) Old 09-13-2008, 11:35 AM
marti5's Avatar
Ok, try a bottle of injector cleaner 1st before you start spending out to much,add the whole bottle to a nearly empty tank ( ignore what it says on the bottle and make sure you get the one for diesel injectors!),then fill it up, see how you go, then if that fails we will go from there.
marti5 is offline
post #5 of 9 (permalink) Old 09-13-2008, 05:37 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
^ cleaner COULD help... But sounds more serious... when did you notice this happening?
When and what was the last service performed on the car. when was the last time it had a tune up?(airfilter fuel filter and such...)?
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #6 of 9 (permalink) Old 09-13-2008, 05:57 PM
MADDOUG is on a distinguished road
The hot start issue is due to the lift pump not functioning when starting on a hot engine,all m51 engined cars do it,rangerover,vauxhall,bmw etc.Injector pump runs hot,over 80deg and fuel evapourates,lift pump will not run until engine starts when warm,on cold start it runs when glowplugs on,hence instant start.My tds (94) does it,but when I add 20% or more veg oil the problem goes away.The stalling and tickover problem will not be related to this.Lift pump lives in diesel tank,around 100 new,but nothing wrong with yours,if you stop car when hot it will start instantly,it's only when you leave it for more than five mins the evapouration occurs and cranking is required.
MADDOUG is offline
post #7 of 9 (permalink) Old 09-14-2008, 10:59 PM
DIRTE30's Avatar
DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute DIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
Vapor lock... you could also try wrapping the fuel lines in a heat sheild like aluminum foil or a fiberglass sheath. Also, try cycling the ignition switch on and off 3 times before attempting to start it after it has sat hot. This will cycle the fuel pump a few times and help to push the fuel back up the fuel lines to the IP. Good luck man! Wish I could get one of those babies over here!
DIRTE30 is offline
post #8 of 9 (permalink) Old 09-15-2008, 07:05 AM
Alas the lift pump will not run on a hot/warm engine start,so cycling it will not work.The vapour lock occurs inside the injector pump itself,there is a fix which involves a resistor or diode that can be fitted to pump relay to make pump run on warm engine although this also fires up the glowplugs as well.The lift pump only runs around 10psi ish pressure if that much,its not a high delivery system like petrol engined cars,and I believe ecu stops and starts it during engine running/fuel pressure sensor in top of filter head,although I may be wrong on that,people running vegtable oil have described signal from ecu as switching off and on when testing pump wiring,this made sense to me as pump does not have a high return flow to tank,it only needs enough fuel to run engine.
MADDOUG is offline
post #9 of 9 (permalink) Old 09-21-2008, 08:48 AM Thread Starter
Gentlemen, many thanks for all your suggestions and comments.
Because the cars in Spain, its difficult to try these straight away, however the injector cleaner has to be worth a try, and is relatively inexpensive, so will do that next time we go in a couple of weeks.
The lift pump suggestion seems logical, but I wouldn't know how or where to fit the resistor, so I will need to find a reliable auto electrician over there, that could be a bit of a task in itself.
As for the engine surge, and stalling, I think I agree that this is a separate problem. I did find another thread on this site from someone else who had the same problems and he fitted a new injector pump which apparently cured the problem, although a trifle expensive. I think I might see how this progresses for a while, the car is only a run about, and you can compensate for these nuances with driving style, even though this is all a bit annoying.
Yes, the car does need a good service, but I don't feel this alone will cure all.
Once again, thanks for the help, and keep them coming if anyone has any further suggestions.
Cheers, P.
BMW E39 525TDS 1999 - Starting problems was4 5-Series (E12,E28, E34, E39, E60) 4 11-05-2011 03:52 AM
lazy starting 525tds bmnkyharris9 5-Series (E12,E28, E34, E39, E60) 4 10-06-2008 08:26 AM
E34 525tds Electronic Igniton problems matalosse 5-Series (E12,E28, E34, E39, E60) 4 07-24-2008 07:21 PM
Stalling In Hot Weather ben_t 5-Series (E12,E28, E34, E39, E60) 3 05-13-2005 07:48 AM
E34 525i Not Starting dynabyte 5-Series (E12,E28, E34, E39, E60) 3 01-28-2005 09:36 AM
