e34 525tds 1995 engine/box/ecu swap - BMW Forum - BimmerWerkz.com
Old 09-09-2010, 07:30 PM   #1 (permalink)
gazbaz25 is on a distinguished road
hi all, ive just join this forum and am hoping for sum help and advice on my current project and future ones to.
well, at the moment i have 2 e34 525 tds, the first 1 is 1995 manual with ews, and a twisted shell, everything inn the car bar the shell is almost mint.
the second is a 1994 auto se which doesnt have ews. it is rather shabby and the engine and box are not very good.
i am in the process of swapping the engine, manual box, ecu, sespention, breaks, interior.
the main problem i have come across at the moment is that the first 1 that i am taking the parts from has ews and the second 1 doesnt.
i dont really want to swap the hole car wiring, so is there another option?
could i just trace the 2 wires from the transponder box by the ignition barrol to the ecu on the first and run sum wires in the seconed and put the transponder box in??
any help or advice would be greatly aprecheated
gaz
gazbaz25 is offline   Reply With Quote
Old 09-15-2010, 01:17 AM   #2 (permalink)
M540I is on a distinguished road
gaz
You can use old wiring with old ECU since engine is the same, make sure your knock sensor plugs are the same, along with oxygen sensor plugs.
If you decided to swap in EWS one, do EWS delete via after market chip or have a BMW tech overwrite it.
M540I is offline   Reply With Quote
Old 09-15-2010, 07:41 PM   #3 (permalink)
hi, thanks for the reply, i have already put the engine manual box and engine wiring loom and ecu in the car.
i dont really want to swap the rest of the car loom as i belive this would be alot of work, ive been told that the wires from the trasponder box on the stearing colum go to a control box behind the glove box, if i can trace the wires from that could i then trancefer them from the old1 to the new1 and connect to the relevent connecters on the ecu? or is this not possable? my ecu has already been chiped i belive but i have no paperwork for this but i no i goes alot faster than standared.
1991 E34 Engine wont start after engine swap pegasusflash 5-Series (E12,E28, E34, E39, E60) 7 12-09-2009 06:13 AM
e34 518 engine swap help please fsvinyl 5-Series (E12,E28, E34, E39, E60) 2 10-06-2009 06:55 PM
E34 Zf gear box swap plug difference beelzebubs FAQ's and DIY's 0 06-03-2008 08:42 AM
1995 318is engine swap Boost 3-Series (E36) 17 07-09-2004 11:24 PM
FS: '91 E34 M5 310hp engine, harness, ECU d993 Classifieds Sell & Buy 0 04-01-2004 12:42 AM
