E34 525i Not Starting - BMW Forum - BimmerWerkz.com
Old 01-25-2005, 07:29 AM   #1 (permalink)
dynabyte is an unknown quantity at this point
My 525 was involved in a minor accident and stood at the shop for an extended period of time. Battery went flat and the guys at the shop decided to jump start it with the cables connected directly to the battery. Now when the battery is connected the hazard lights come on even though the hazard switch is not activated, and a relay in the relay cluster under the rear seat clicks away merrily, stopping from time to time. The engine cranks over and there is a spark, but it appears that the power to the fuelpump relay has somehow been cut.
Any ideas, suggestions , as I have run out and would like to get the car running again. It has the M50 motor with single Vanos, and the S11 computer with firmware dated around 1994.
Thanks
dynabyte is offline   Reply With Quote
Old 01-26-2005, 06:05 PM   #2 (permalink)
billB's Avatar
Thanks
[snapback]278724[/snapback]
Review:
hazard lights on+relays clicking+fuel pump cut off switch triggered by accident and jumping battery=Alarm cutting off problem? Anyone?
Old 01-27-2005, 01:27 PM   #3 (permalink)
///Matt's Avatar
I would say he's got relays that are either damaged or installed incorrectly. Maybe they got fried with the jump-start?
Old 01-28-2005, 08:36 AM   #4 (permalink)
I'd be pushed toward the electronics being fried from the jumpstart. The car shouldnt be jumped directly to the battery, thats why there are specific jump points in the engine compartment.
Also, if they didnt turn on all the electronics in the car (heater, lights, etc) when they remove the jumper cable, the power surge could get to sensitive electronics and cause similar problems. It happens more often than you might think.
Question regarding E34 front carpets m3driver97 5-Series (E12,E28, E34, E39, E60) 0 10-13-2005 02:32 PM
Starting Problems BMWDriver86 3-Series (E21, E30) 15 02-09-2005 04:28 PM
Cold Starting _1634_ 3-Series (E36) 2 09-07-2004 04:03 PM
325i vs 525i Bengal94 3-Series (E46, E90) 2 10-25-2003 09:51 PM
