| Ideas:
If you aren't already, use the higher grade gasoline for your car
Check your fuel pump and fuel filter, replace if needed (what the hell, why not)
Remove anything in your car that is adding weight (if there is anything)
__________________ <span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span> |
