Hi, I went to check neighbors vehicle. (Issue is car cranks and no-start)
Fault code# 66 alarm system
Google forums said to by-pass the (EWS)yellow box, under steering column.
By, Splicing wire #1 to #3 , cause... Car Now (Cranks-no start)
Now, i feel stuck..Car cranks and doesn't start. Why?
Is there away to by-pass EWS system? Can you guys tell me steps to take.:|
Fault codes #66
Fuses, ok
Fuel pump,relay ok
Ignition system, ok
Battery, ok
Starter, ok
Fault codes #66
Fuses, ok
Fuel pump,relay ok
Ignition system, ok
Battery, ok
Starter, ok
