E28 Problem - BMW Forum - BimmerWerkz.com
Old 05-02-2010, 12:16 PM   #1 (permalink)
brettpv9 is on a distinguished road
E28 Problem
I am having a hard time keeping the car running after I cleaned under the hood with some Gunk spray. Once I rev the engine past 2kRPM, it dies....
I cleaned on the driver side really only the steering components and that side of the block. any ideas?
brettpv9 is offline   Reply With Quote
Old 05-04-2010, 01:16 PM   #2 (permalink)
Car: 1995 530i & 1986 535i
jimoreno is on a distinguished road
It sounds like you have moisture in your electrical system. Did you do this with a warm engine? If you did, there could be condensation inside your distributor cover due to the cooling effect. Anyways, remove the distributor cover, dry it with a clean rag and spray some WD-40 inside. Let it dry and re-install, start your car! Also, maybe the cleaning pulleed a connector just enough to open the electrical connection so check each and every connection and make sure that it's tight and dry. You didn't specified which model you have but if it is a 528e, check the AFM connector (it is on the driver's side for this model)
jimoreno is offline   Reply With Quote
M5 E28 the real feanor M-Series (M1, M3, M5, M6) 5 05-06-2006 11:26 AM
Anybody With A E28 Hoppy's535i 5-Series (E12,E28, E34, E39, E60) 18 03-17-2005 09:04 PM
Tach Problem With E28 islandbimmer 5-Series (E12,E28, E34, E39, E60) 0 11-25-2004 07:53 PM
My 528i E28 cnetral locking problem Sexy Daz 5-Series (E12,E28, E34, E39, E60) 1 11-10-2004 12:09 AM
528i E28 Central Locking Problem Sexy Daz Classifieds Sell & Buy 0 09-08-2004 08:57 AM
