E28 Help With Brake Lights - BMW Forum - BimmerWerkz.com
Old 10-12-2004, 07:04 PM   #1 (permalink)
afroken is an unknown quantity at this point
i just recently bought a 1983 528e automatic from a friend for 200 bucks (what a deal!!!) it runs brilliantly except for the fact that the brake lights dont work. the check light (by the sunroof) wont go off and the bulbs are brand new (bmw approved). i've tried everything i can think of, the brakelight switch is new, bulbs are new, connections have been checked for corrosion and cleaned, i've even tried touching the brakelight switch connectors together. aftermarket radio shares the #12 fuse and i've tried taking the radio connection off...nothing has worked. thanks in advance for any advice.
phil
1983 BMW 528e automatic
1981 Datsun 280zx 2+2 5spd.
p.s. - can anyone tell me what the VDO box is, its located under the steering wheel inside the dash, thanks.
afroken is offline   Reply With Quote
Old 10-12-2004, 07:15 PM   #2 (permalink)
Hoppy's535i's Avatar
Hoppy's535i is an unknown quantity at this point
check the fuse. and i donno waht the vdo box
<span style='font-size:11pt;line-height:100%'><span style='color:blue'> theres no replacement for displacement </span></span>
Hoppy's535i is offline   Reply With Quote
Old 10-12-2004, 07:45 PM   #3 (permalink)
[snapback]210115[/snapback]
the fuses are tip top. thanks for the input
Old 11-09-2004, 11:37 PM   #4 (permalink)
Hakos3d is an unknown quantity at this point
I've been working on my 535i since I bought it (6-7 months with pleasure). I installed a new sound system with 6x9 speakers and stuff. But when I was hitting the brake, the lights would dim and my amp would go off. O blamed the braking system and inspected everything electrically. And by the way, this is the first time I'm ever working on a car although worked on electrics and computer hardware before. There's a button right above the brake pedal. When the pedal is released it is already pushed so the lights are off. But when you hit the pedal, the button is released and the brake lights go on. See if everything is Ok, by the way that buttonis all mechanic. You don't have to check anything else in the car. Just the brake line which is getting the energy from the fuse box and activated by that button. Good luck!
Hakos3d is offline   Reply With Quote
HELP - Brake, ABS, and DSC lights on Fangs 3-Series (E46, E90) 48 05-13-2011 01:39 PM
Brake Lights Stay On Nealdavis4 3-Series (E21, E30) 0 12-17-2004 01:21 AM
Brake Lights No Work Wtf?? daxsandman 3-Series (E21, E30) 2 12-07-2004 04:38 PM
Brake Lights Failure, Now. bkstaylor 3-Series (E36) 1 11-24-2004 09:45 AM
