E28 535i overheating - BMW Forum - BimmerWerkz.com
post #1 of 14 (permalink) Old 01-02-2011, 03:52 PM Thread Starter
Wanzzilla is on a distinguished road
Exclamation E28 535i overheating
Hey all I am new to forums and after intensive search I came up empty and hope you all can help me with my problem.
I have a 86 535i e28 BMW and it has been overheating like crazy, I started off with replacing the thermostat, then replaced the fan clutch, then replaced water pump, then replaced thermostat and housing this time, still overheating, replaced radiator, replaced dashboard cluster and the IS board as well. Also replaced both temp sensors on the side of the radiator as well. It overheats whether I am at idle or driving down the road or highway. I have also replaced and bled the system three times and so now I am just plain frustrated! Any help on this pain in the butt issue would be great! Will welcome any ideas or input
Wanzzilla is offline
post #2 of 14 (permalink) Old 01-02-2011, 05:31 PM
Quoted: 1 Post(s)
Almost seems like an issue with bad coolant flow through the cooling jacket around the block.
witeshark is offline
post #3 of 14 (permalink) Old 01-02-2011, 05:57 PM
42, The meaning of life
brettski's Avatar
brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice
Welcome to the Werkz. Is it possible that your engine is running lean for some reason?
Was there any work done that preceded this issue?
Riding in style
brettski is offline
post #4 of 14 (permalink) Old 01-02-2011, 07:30 PM Thread Starter
Well I bought it last year and prior to that I do not know what wasndone to it, I know that I replaced the fuel injectors with 19lbs injectors and the work that I already put down was all the work that I have done to it but I was told that the oil was changed and the change oil light always stayed on and it needed to be fixed, I found out what is was through this board :0) and changed it. How do I check the jacket around the block? Would there be a block somewhere through there? This is my first BMW and I love it and am trying to restore it at the same time, would this also account for the temp gauge bouncing around? Like it will move back forth from semi cool to hot then to overheating slighty To then jump close to the red and then back down again? And also I have tried to turn the heater on full blast and it does nothing to the engine it at all per the temp gauge, could it possibly be a sensor? Sorry for the long post, I am trying to give as much info as possible on my issue that is seriously chalking my hide
post #5 of 14 (permalink) Old 01-02-2011, 07:53 PM
Quoted: 1 Post(s)
It may be there're still some pockets of trapped air in the system.
post #6 of 14 (permalink) Old 01-02-2011, 08:11 PM
brettski's Avatar
Does the heater consistently blow hot air when you have it on its highest setting?
Riding in style
brettski is offline
post #7 of 14 (permalink) Old 01-02-2011, 10:40 PM Thread Starter
As soon as the engine is warmed up it will blow hot air out on all settings
post #8 of 14 (permalink) Old 01-02-2011, 10:49 PM
brettski's Avatar
Is there any sign of oil (milky appearance) in the coolant expansion bottle, or of coolant in the engine oil? Maybe a cracked or warped head or leaking head gasket? Is it using any coolant at all?
Riding in style
brettski is offline
post #9 of 14 (permalink) Old 01-02-2011, 11:44 PM Thread Starter
No milky appearance in my coolant, I can't see or find any leaks either, and the coolant level is not dropping either, it's killing me on what it could be!
post #10 of 14 (permalink) Old 01-03-2011, 10:27 PM
gidgaf is on a distinguished road
Sometimes ... it's more than one duck.
■ If you have a pocket of air trapped behind the thermostat it won't usually open, thus preventing the water from flowing correctly. If you have a pocket of air at the water pump it will cavitate, and water won't flow. If you have sludge or mineral deposits (you DO use distilled water, right?) they'll build up and act like restrictive insulation and you can overheat, even if water flows. If you have an old flimsy lower hose it can sometimes collapse, preventing the water from flowing.
So, as an old fart I usually drill a couple 3/16 holes in the thermostat before I install it. This lets the air escape right on thru, and it also allow a little water past so the thermostat acclimates immediately.
You know how the temp gauge bounces around? That's pockets of air mixed in the water. Mine used to do that. With the new and holey thermostat it just climbs to 1/3, and stays there. My advice? Trust nothing, check everything.
Pull the thermostat and put it in a pot on the stove, with a candy thermometer. Make sure it opens at the right temperature. While you're doing this put the housing back on, add some coolant system flush, and see how much crapola comes out. While you're doing that, check the fan and the fan clutch. Does it actually work and spin the fan, is there a lot of air rushing thru when you first start it and again when it gets hot. When you changed the temp sensors on the radiator did you check to see if they work, does that front fan really work, and does it work like a two speed fan? Did you make sure there's a clear air path, from the front of the car, thru the AC and water radiators, and out? Did you check the hoses, make sure they are fit functional not pinched or dented and they're routed correctly, if there is a bypass hose make sure it's not clogged with goo, and make sure the overflow tank is half full *all the time* until this is working properly.
gidgaf is offline
post #11 of 14 (permalink) Old 01-03-2011, 10:40 PM Thread Starter
Gidgaf, thanks for the help I will do all that as soon as I can, one question though, I just bought allnthese replacement parts, what arenthe odds that the new part would go bad as soon as I put it in? Well I just use 50/50 antifreeze which from the sound of things that is not a good thing? So what should I use instead? Or should I use just distiller water only and maybe add some water wetter to it?
post #12 of 14 (permalink) Old 01-07-2011, 04:51 PM
Wanzzilla, there's not a lot to go wrong, especially if you check up on things. Did you check the thermostat on the stove? It should still be as good as that. Unless something bad happened to new hoses and they were installed correctly and they don't leak, they're still good. IF the water pump works AND the thermostat works AND the radiator is clean AND the hoses are good AND it's full of water AND the fans work AND the fuel/air mixture is right there should be no reason to overheat. EVER.
Did you ever check to male sure the fans work? My engine mounted fan goes VROOM! for a minute in the morning, and when it's idling I can hear it on occasion, starting up and shutting down. I never checked that my sensors actually started my electric, (I am soon, now!) but I do know the fan works and that the sensors work. Di you ever put your hand on the radiator and all the hoses to see if it was actually getting warm? Did you double check the reservoir level?
50/50 antifreeze is not bad. It ain't the best, but it's almost always good enough. I live in Hell-A, where where we've had a couple of the coldest nights for quite a while: down to 44 degrees at my house. THAT mean 35% antifreeze works the best for me, as far as heat transfer and aluminum protection. Read the label on your water wetter product- some of them make a big deal out of a couple degrees .
A good engineer/ mechanic/ programmer quote: the first 90% of the work takes the first 90% of your time and money. The final 10% takes the other 90%. Fix the big and easy stuff first! Did you check the temp sensor ...
gidgaf is offline
post #13 of 14 (permalink) Old 02-09-2011, 07:24 AM Thread Starter
Sorry for the long delay, but I live in Texas and my car was in California when this happened and I had to come back to Texas, so I had to go through a friend to another mechanic to talk to him to tell him what I had done and what the problem was, well as it turned out it was two fold, the water jackets were somewhat clogged up and the thermostat was bad, which is crazy because that was the third one I put in. I think I just have bad luck with those things LOL, anyways she is back up and running and I wanted to thank everyone for there great imput and possible ideas of what it could have been and what to look for. Thanks a lot everyone!!
post #14 of 14 (permalink) Old 02-09-2011, 09:45 AM
Quoted: 1 Post(s)
Glad it's resolved!
E36 318i overheating and not overheating !!?? lucky178tb 3-Series (E36) 7 07-20-2009 07:16 PM
Overheating!!! POCKETROCKET 3-Series (E36) 3 06-15-2009 07:51 PM
Odd overheating Raymond 3-Series (E21, E30) 5 05-20-2008 09:33 PM
03' M5 overheating SpecialK M-Series (M1, M3, M5, M6) 6 04-29-2008 01:00 AM
Overheating jonnyblaze 5-Series (E12,E28, E34, E39, E60) 6 04-06-2005 11:45 AM
