E Box - BMW Forum - BimmerWerkz.com
Old 05-02-2005, 01:16 PM   #1 (permalink)
Wade6923 is an unknown quantity at this point
I can,t find the ( E Box ) which holds the windshield wiper relay. I was told it was located under the hood, under the air intake for the passanger. I see no bolts or other way to remove any type of cover ghead
I can only find relays in the trunk and can't tell if any of these are for the wipers. They appear to be a dry type relay and therefor should be able to hear or feel a click when operated, but I can't.
Wade
Wade6923 is offline   Reply With Quote
Old 05-02-2005, 03:30 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Which car is this on ?
Old 05-03-2005, 02:51 PM   #3 (permalink)
97 540i cant find the E Box
Old 05-04-2005, 02:11 PM   #4 (permalink)
jday is an unknown quantity at this point
I have a 95 525i and my e-box is on the passenger side of the engine compartment straight across from the fuse box against the firewall. It has screws that hold the top on. Looks similar to the fuse box. Hope this helps!
jday is offline   Reply With Quote
Old 05-04-2005, 03:27 PM   #5 (permalink)
Eric S.'s Avatar
Eric S. is on a distinguished road
[snapback]340528[/snapback]
Wade, your E39 1997 5-series is very different from the E34 the person above was referencing.
My 1999 E39 is very similar to your car, and I just replaced my windshield wiper relay. It is easy. Here is what you do:
1. In the engine compartment, all the way back by the firewall and at the base of the windshield, you have a cabin air filter box on each side of the car. Using a screwdriver, dislodge the three airtube clips from the passenger side box (right side of the box as you are standing looking at it from the front of the car).
2. Unclip/lift the wire bail holding the lid on, remove the lid, and remove the cabin air filter (consider replacing this filter).
3. At the front of the box, centered, but at the bottom is a spring clip holding the box onto a short threaded rod. Squeeze the spring and pull up on the clip and box to free the box. Remove the box from the car.
4. Now you should be able to see the plastic top of the e-box. You'll need a 5mm hex key to loosen and remove all 4 socket head cap screws holding it on. Be patient, the threads are fine and it requires a bit of turning.
5. Remove the box top. Underneath are a bunch of relays and stuff. In my case, the w/w relay was the tallest one, tan in color. It simply lifted out. The new one was in stock at my BMW dealer and was under $15.
6. Good luck to you! It should be about a 10 minute job.
<span style='colorurple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline   Reply With Quote
Old 05-05-2005, 06:04 AM   #6 (permalink)
Originally posted by Eric S.+May 4 2005, 03:27 PM--><div class='quotetop'>QUOTE(Eric S. @ May 4 2005, 03:27 PM)</div><div class='quotemain'><!--QuoteBegin-Wade6923@May 3 2005, 03:51 PM
[snapback]340840[/snapback]
[/b][/quote]
Thanks for the info, it was right on the $ however myrelays were two purple ones and I went to autozone and bought new ones, when I replaced them both I know blow one of my wiper fuses and ideas before I start to trace it out?
Old 05-05-2005, 06:54 AM   #7 (permalink)
Eric S.'s Avatar
Originally posted by Wade6923+May 5 2005, 07:04 AM--><div class='quotetop'>QUOTE(Wade6923 @ May 5 2005, 07:04 AM)</div><div class='quotemain'>
[snapback]341039[/snapback]
[/b][/quote]
I didn't quite follow your shorthand. It sounds like you have 2 purple relays for your wipers and that when you replaced them you blew a fuse? All I can say is to get the Bentley manual - its electrical diagrams may be of use. Also, don't forget that there are a bunch of fuses and stuff back in the trunk with the battery.
Oh, and try to go OEM on things like relays (just my O). In my case, my BMW CCA membership gets me 20% off parts prices at the dealer, so they are usually competitive on price.
Good luck.
Old 05-05-2005, 03:27 PM   #8 (permalink)
Moderator
Dirty_Tool's Avatar
The fuses blowing os probably due to the aftermarket relays. Get the correct parts in there and see if that takes care of it.
DT
DT
Help Needed!!!!!! chrismcl05 3-Series (E36) 7 10-04-2005 12:05 PM
Weird Shifting Between 2nd And 3rd ozarkmark 5-Series (E12,E28, E34, E39, E60) 15 09-21-2005 08:11 PM
E36 m3 sagging glovebox. Fixed. Mostly. 4evrwyntr 3-Series (E36) 9 09-11-2005 11:36 PM
AIR BOX DEBAFFLE *help please* White e36 dude 3-Series (E36) 6 09-10-2005 03:17 PM
