Dumb Question
983 views 2 replies 2 participants last post by  Hoppy's535i
#1 ·
stupid question, i should know the answer but ho do i get the roundels off? both the hood and trunk of an e28
#2 ·
There are two prongs in the back, one at 3 and one a 9. I used a thin flathead to get underneath and pop off the front one on mine.
You may feel more comfortable using a plastic knife or rubber putty knife to not scratch the surface underneath, but if you're careful it's not a problem.
Or you could dissasemble to inside of the hood and trunk and get at it from there. :wink
#3 ·
ya, i wanna pop it off with the rubber things in tact. the hood is already exposed so i can get that from under nieth. guese il just pry the trunk one off
