Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 01-17-2005, 09:42 AM   #1 (permalink)
dberger's Avatar
Photos: 0
dberger is an unknown quantity at this point
Today I started my car (-10 below zero ) and I noticed the right side of the cars vents blew cold air while the driver sides vents blew hot air. I had both sides set to 90 degrees with the middle dial set to 3 red circles (hot). Am I missing something or can it be that the "Dual Climate Control" is busted on the right side?I have closed all passenger vents just so the car will warm up. It's a 1998 528i. Any help will be appreciated.
dberger
dberger is offline   Reply With Quote
Old 01-18-2005, 12:11 PM   #2 (permalink)
Photos: 0
frank3 is an unknown quantity at this point
I sure sounds like the climate control switch on the right side is broken...I'd start there.
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 01-18-2005, 01:02 PM   #3 (permalink)
///Matt's Avatar
Photos: 0
Send a message via AIM to ///Matt
I have the exact same problem....people have been telling me a broken heater valve....
1997 540i - 200,000 Miles Strong
1988 325ic - Still at 16,000 Miles
1987 635csi L6 - In Restoration(To be completed April 2007)
///MATT
Old 01-18-2005, 01:08 PM   #4 (permalink)
dberger's Avatar
Photos: 0
Has anyone fixed the problem before? or are you just closing those vents for now?
Dan
Old 01-19-2005, 12:36 PM   #5 (permalink)
dberger's Avatar
Photos: 0
Funny thing today....... All vents now blow warm air.
Old 01-19-2005, 12:42 PM   #6 (permalink)
Photos: 0
[snapback]274052[/snapback]
If it were a broken heater valve, then you would have simultaneous problems with heat on the left and right side. There's only one heater valve that sends heat to the passenger compartment. The problem lies with the dual climate controls...either electrical, or vacuum (which would cause the vents on one side of the car to either not open or not close).
Old 01-20-2005, 07:19 PM   #7 (permalink)
Photos: 0
I am not that familiar with your car but on my E32 we have stepper motors (air distribution motors) and they control the opening and closing of the various vents in the dash of the car. Occassionally the main controller gets confused and at shutdown the valves are not positioned to the default position or the controller gets confused during selection of a mode and does not correctly position the valves according to your selection. Rebooting (shuttting the car off and then giving her a few minutes to settle before restarting the car) MAY, at least temporarilly solve the problem. Do you ever hear a humming sound behind the dash at shutdown or when first turning on the ignition (prior to start) if yes, those are the steppers.
Old 01-21-2005, 04:26 PM   #8 (permalink)
dberger's Avatar
Photos: 0
[snapback]275776[/snapback]
there is a faint sound- buzzing when it is cold out with the car not started, why is that?
Dan
Old 01-23-2005, 01:31 PM   #9 (permalink)
Photos: 0
Originally posted by dberger+Jan 21 2005, 03:26 PM--><div class='quotetop'>QUOTE(dberger @ Jan 21 2005, 03:26 PM)</div><div class='quotemain'><!--QuoteBegin-Bear@Jan 20 2005, 06:19 PM
I am not that familiar with your car but on my E32 we have stepper motors (air distribution motors) and they control the opening and closing of the various* vents in the dash of the car. Occassionally the main controller gets confused and at shutdown the valves are not positioned to the default position or the controller gets confused during selection of a mode and does not correctly position the valves according to your selection. Rebooting (shuttting the car off* and then giving her a few minutes to settle before restarting the car) MAY, at least temporarilly solve the problem. Do you ever hear a humming sound behind the dash at shutdown or when first turning on the ignition (prior to start) if yes, those are the steppers.
Dan
[snapback]276268[/snapback]
[/b][/quote]
Old 01-23-2005, 01:34 PM   #10 (permalink)
Photos: 0
If the buzz is coming from the engine compartment, drvers side , it is the stepper motors repositioning themselves. This is a commoin happening but to those of us not familiar with the BMW way of doing businnes it can be scary. On my'88 E32 you can hear the fan for the DME Motronic box humming away at start.
vB code is On
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 10:09 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 12:51 PM
Climate Control Module Upgrade E46 BMWNUT 3-Series (E46, E90) 0 10-21-2004 02:09 PM
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 2 09-02-2004 02:14 PM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 20 07-22-2003 11:44 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
