driveshaft cv joint - BMW Forum - BimmerWerkz.com
Old 01-07-2010, 02:32 PM   #1 (permalink)
Bruzda1 is on a distinguished road
driveshaft cv joint
can anyone describe symptoms of bad cv
thanks
Bruzda1 is offline   Reply With Quote
Old 01-07-2010, 03:38 PM   #2 (permalink)
I'm pretty sure you'd hear some sound between click and clunk during full lock turns.
Old 01-07-2010, 04:49 PM   #3 (permalink)
i can hear clicks while in reverse, only 2 or 3 nothing when turninig, but there is very small vibration from the rear, feels like driving over very fine bumps
Old 01-14-2010, 02:02 PM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
My 840 used to vibrate between 20-25 mph then the vibration would go away. It turn out to be the cv joints. I replaced the whole drive shaft also ($700 for the part, installation took less than 1/2 hr.
You're better off by replacing the whole drive shaft if you can afford it.
You'll hear a clunk noise for your cv's
LOS
Old 01-14-2010, 02:50 PM   #5 (permalink)
i just replaced guibo and csb, my mechanick diagnose as diff and subframe bushing, we are going to replace it next week, will keep u info
Old 01-14-2010, 03:04 PM   #6 (permalink)
Best of luck with it!
Old 02-05-2010, 08:09 AM   #7 (permalink)
update, diff and subframe bushings replaced, car dives much better, but therre is still minor vib between 15-35mph and feels like it is comming from driveline (somwher in front)
all suspension have been replaced, guibo, csb,engine and tranny mounts, spark plugs , valve cover, prytt much everything that coud cause vibrations;
any ideas?, forgot to mention - new wheels anf tires (raod forced balanced)
U Joint Going Out Help!!!!!!!!! erbeman 3-Series (E46, E90) 5 10-15-2008 09:53 PM
driveshaft flex joint keple9801 3-Series (E36) 1 09-10-2008 04:52 PM
driveshaft flex joint hk30 3-Series (E21, E30) 1 07-06-2008 04:02 PM
U Joint Rkhoubian 5-Series (E12,E28, E34, E39, E60) 3 04-12-2005 06:18 PM
Is this the U-Joint? e36 3-Series (E36) 10 06-25-2003 06:13 AM
