Door will not open - 1998 e39 - BMW Forum - BimmerWerkz.com
Old 02-08-2012, 08:25 AM   #1 (permalink)
Car: 1998 E39 523i - Black leather trim
Raaid is an unknown quantity at this point
Some months ago, after unlocking the car with the remote, I found that the driver's door would not stay shut, so I got out, operated the remote (lock/unlock) and on re-entering the car, the door shut properly. All seemed OK until I tried to get out - but the door would not open no matter what I did with it !!
We could only rip out the driver's door card, fiddle with the lock which seemed to work, then fit a replacement door card!!!
All went well for a couple of months but then on Friday, the car decided to lock me in again!!
As before, using the remote to unlock the car worked fine, all door plungers/rods responding to the remote, but the driver's door would then not latch closed. Using the remote once more, the door closed properly - but refuses to open now with the remote or key!!
I've tried operating the inside and outside door handles simultaneously, and also leaving the car for some time with the battery disconnected, but I still cannot unlock the drivers door.
Since the door rods move OK, does this rule out a faulty door actuator (67118352165) ?
Anyone had the same problem?
Raaid is offline   Reply With Quote
Old 02-08-2012, 02:28 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Has to be the actuator... Try pulling the interior catch twice when locked inside, if this doesn't work then I am right... "If" I am, check the connections first, the connector blocks can sometimes "Need Wakin'-Up" lol
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 02-09-2012, 06:59 AM   #3 (permalink)
Thanks Dabsy - so am I wrong in thinking that the door rods are moved by the actuator?
I've tried pulling the interior handle a few times, so it looks as if there is no option but to break through the door card and see what is causing the lock to jam again.
Old 02-09-2012, 01:33 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
No, you may not be wrong !!
Best way is to get the card off and inspect the rods and nylon holders, if all seems fine then test the actuator.
Eso es todo!
BMW Part Market
New Member ?
Old 02-17-2012, 09:47 AM   #5 (permalink)
Still off the road, waiting to find a driver's door trim panel in black leather before I get the garage to break through the existing panel.
Anyone have a panel for sale?
Old 02-17-2012, 03:07 PM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
You should still be able to pop the door-card off while its closed !!
Eso es todo!
BMW Part Market
New Member ?
Old 02-17-2012, 04:40 PM   #7 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
It should be possible. The only thing in the way is the seat and steering wheel. The hard part is you would have to be carefull but replacement clips are available if you break them.
Their are replacement door panels on EBay. I found a set of four in biege for $250 + shipping.
Click HERE to see my E36 Blog
Old 02-18-2012, 05:54 AM   #8 (permalink)
Door Trim Panel
I didn't think that removal of the driver's door panel was possible whilst the door is closed.
When it happened before, the garage broke through the panel, which then had to be replaced.
Perhaps I took the car to the wrong garage!
Old 02-18-2012, 05:58 AM   #9 (permalink)
Door panels
Thanks, but if necessary I'll just replace one panel - which in UK will cost me around £25 ($40).
Exterior Door handle won't open door crynow82 3-Series (E46, E90) 2 03-02-2012 10:57 PM
HELP! door won't open gt3guru 3-Series (E36) 2 08-17-2009 11:58 PM
1998 Bmw750il Door Open Message Willb395 1,6,7,8 - Series and Mini Cooper 0 04-13-2005 09:21 AM
Door Won't Open From The Outside? lavalva 3-Series (E36) 10 04-05-2005 06:22 PM
My door won't open Eggrolled211 3-Series (E36) 5 12-03-2003 11:23 PM
