Door Lock Problems - BMW Forum - BimmerWerkz.com
Old 06-20-2006, 12:18 AM   #1 (permalink)
Car: 1990 BMW 535i
MarylandTim is on a distinguished road
Send a message via Yahoo to MarylandTim
Question Door Lock Problems
I have a 1990 535i. I locked all the doors as normal with the key. And later when my wife went to unlock it (with the key) all the doors unlocked except the driver's door. So now the driver's door is locked and will not unlock. You can not unlock it by key or manually. All the other doors unlock and lock manually. Does anyone have any idea what might be causing this?
MarylandTim is offline   Reply With Quote
Old 06-20-2006, 05:20 AM   #2 (permalink)
da_administrator
da_bull's Avatar
Yup, I had the same problem with my passenger door. If you cant manually pull up on the inside lock, the electronic actuator is bad. I have priced these from 139-160 each. I am working on another solution using a Spal universal 5 wire actuator. They are only about 25-30, but wont plug straight in, it entails rewiring. I am hoping this solution works, if not I gotta buy the one from the stealership...
Old 06-20-2006, 09:25 AM   #3 (permalink)
Car: 1990 BMW 535i
Thanks Bull. Now how in the world can I install an actuator if I can't open the door?
Old 06-20-2006, 07:47 PM   #4 (permalink)
Car: E39 & E46
16valex is on a distinguished road
That's really sucks, you gonna have to try to wiggle the key manually and hope for the best.
Alex
16valex is offline   Reply With Quote
Old 06-20-2006, 09:53 PM   #5 (permalink)
da_administrator
da_bull's Avatar
I had to roll the window down, get hold of the plastic door lock piece with a set of pliers. CAREFULLY lift up, while trying the outside handle. It feels like you are going to break it. It will come up enough to open the door. What I did was remove the electronic actuator and put it back together. It renders the one door back to manual, and the outside lock doesnt unlock that door, you can only unlock it from the inside. The outside lock will still electronically lock/unlock the other 3.
I'm not sure if I'd use the key, as 16valex said, it may break off, its REALLY tight. I tried the key at first and it REALLY felt like it could break.
94 325is Problems sre2114 3-Series (E36) 23 10-21-2004 04:27 PM
cert pre-owned '01 330xi problems mcflier2 3-Series (E46, E90) 5 07-27-2004 03:24 PM
