Does a 95 M3 engine fit into my 92 525i 5spd - BMW Forum - BimmerWerkz.com
Old 04-21-2004, 05:16 PM   #1 (permalink)
domanoukian is an unknown quantity at this point
Send a message via AIM to domanoukian
Post
I have a 1992 525i m50 5spd and found a 1995 M3 parting out. I wanted to know if the engine tranny and diff would fit into my car, and is it fairly easy? also what else would I need ECU. exhaust manifold etc.. thank you sooo much!
domanoukian is offline   Reply With Quote
Old 04-21-2004, 05:26 PM   #2 (permalink)
CiscoKid's Avatar
it will fit
Old 04-21-2004, 05:44 PM   #3 (permalink)
Thank you for letting me know it fits I also need to know what I need, do I need the M3 transmission, or will my stock work, and can I use the 95 M3s differetial, when I install the new ECU will it plug-and-play so to speak, or do I need a whole new wiring setup. Lastly do I need the M3's exhaust manifold, or will my stock exhaust work (dinan muffler) thank you!
Old 04-21-2004, 06:53 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
you would need the ecu, probably would plug right since they were made at almost the same time...3 year difference.
if you have a stick in the 525 and the m3 is a stick, it would be real easy to swap the tranny too... if one is stick and the other one auto, it would probably cost you to much time and money, and would be best to stick with whatever you got.
keep us updated.
Old 04-21-2004, 06:54 PM   #5 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
my bad... missed something in your post
DEFINITELY SWAP THE TRANNY TOO !! good luck
Old 04-22-2004, 12:45 AM   #6 (permalink)
Custom engine mounts will have to be made, as well as tranny mounts... I think this can be a very expensive project!!
Old 04-23-2004, 08:12 PM   #7 (permalink)
Hey guys, thanks for the feed back, but I have mixed reviews. Isnt the m3 s50 motor and the 525i m50 motor the same block therefore using the same engine mount. I'm not sure and am asking, please let me know thanks!!
Old 04-23-2004, 09:00 PM   #8 (permalink)
CiscoKid's Avatar
you might need a new mount
95 525i engine TDC w/VANOS yaofeng 5-Series (E12,E28, E34, E39, E60) 0 11-06-2005 05:39 PM
E34 525i Engine Knocking riverarb 5-Series (E12,E28, E34, E39, E60) 6 10-21-2004 08:24 AM
