Diy: Gauge Cluster Light Delete - BMW Forum - BimmerWerkz.com
Old 08-03-2005, 01:39 AM   #1 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Thumbs down
Here's how you do it.
You let the lights in your gauge cluster burn out on their own.
I did it. Now at night when I drive I cant see my tach/speedo/temp/gas gauges.
Sweet huh?
All out at once? Am I going to have to buy a new cluster? The LED strip at the bottom was alreayd burnt out.
and I dont have tilt wheel
Old 08-03-2005, 03:07 PM   #2 (permalink)
Scotty Dangles is an unknown quantity at this point
Sweet huh?
[snapback]367012[/snapback]
Sorry to hear about your situation...I know how you feel...
FYI - You don't need a tilt wheel to remove the gauge cluster...just loosen the steering column and it will drop low enough for you to remove the gauge cluster...just be careful not to engage the airbag...and disconnect the battery...
Let me know if you need help, I just recently changed all the bulbs in my gauge cluster...
Good Luck
Scott
Scotty Dangles is offline   Reply With Quote
Old 08-03-2005, 11:41 PM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
Did you check the fuses yet?
DT
DT
Old 08-04-2005, 12:44 AM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Yeah fuses checked.
Scotty .....
I've owned my BMW like 3 years now and it has just struck me.....I don't have an airbag....
....whoa
Old 08-04-2005, 04:06 AM   #5 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Check bmwe34.net for the capacitor fix... they might be the problem since it all went out at once.
Old 08-04-2005, 07:46 PM   #6 (permalink)
The capacitors generally have different symptoms. They usually cause erratic gauge behavior.. not lack of lighting.
The bulbs are a super easy job though... 30 min tops.
Old 08-09-2005, 01:58 PM   #7 (permalink)
Originally posted by ///M Power@Aug 4 2005, 12:44 AM
Yeah fuses checked.
Scotty .....
....whoa
[snapback]367249[/snapback]
Well sorry that I had to be the guy that made you realize this...on the flip side at least you don't have to worry about engaging the air bag when replacing the bulbs!! :P
Speaking of replacing dash bulbs...my damn temp gauge bulb went out on me last night...I will replace it tonight....I'm so bitter...
Cheers!
Old 08-09-2005, 03:19 PM   #8 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
I dont know if this could really be bulbs. I mean for them all to go out at once? Before they all went out at once, it had once before had just the left half gone out. How ghetto! Anyone else have any similar issues or ideas?
Old 08-09-2005, 05:52 PM   #9 (permalink)
[snapback]368544[/snapback]
Have you actually tried changing the bulbs yet? Maybe it was a freak occurence that all bulbs went out at once...or a random surge of power??
If changing the bulbs don't do the trick, other then a blown fuse I have no clue what the problem is...maybe it is the famed capacitor issue...but then again your symptoms aren't similar to those of the capacitor problem??
I do have one theory..hear my out now...maybe, just maybe, your car is attempting to communicate with you, and that message would be, "GET A FREAKIN AIRBAG!" haha :P
Really, try replacing the bulbs, its cheap and its not that difficult to do.
Good Luck
Scott
Old 08-10-2005, 01:18 AM   #10 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Hahaha scott. I think my steering wheel looks good without a airbag. Looksso much better. Plus when I die, the medical examiner will be all like, "Damn that steering wheel is stock? Shit it looks nice!"
But yeah I guess ill try and change the bulbs. I just dont want to undo steering wheel and all that nonsense. FUCK YOU NO TILT WHEEL
Old 08-10-2005, 04:07 AM   #11 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
[snapback]368634[/snapback]
at least u dont have a airbag to worry about... i have a burned out bulb on the gas level gauge which i dont think i'll ever change.
damn airbag.
Old 08-10-2005, 09:23 AM   #12 (permalink)
hahaha...gotta love this convo...!! My steering wheel doesn't tilt either...piece of shit...after breaking some plastic parts off my gauge display I had no choice to lower the steering column...son of a bitch!!! ghead I couldn't fit the gauge cluster back into place!!! haha
In any case don't remove the steering wheel...trust me just rip the decorative wood and you will have access to all the screws...remove all the screws and the dash parts will come off so easy...then there is a metal thingy you have to remove..that easy as piss to take off. Lastly you will have two screws holding the steering column up...unscrew them and drop the column and voila...oh one more thing...disconnect your battery...you'll get the SRS light...oh wait does that even apply to your car??? hahahaha
Gauge Cluster Light Burnt Out Silverstreak 3-Series (E36) 3 02-19-2005 12:23 AM
Help! A Very Headache Gauge Light Problem shuiyuan 3-Series (E36) 3 12-18-2004 09:25 PM
Gauge Cluster Problem BMWGuy325i 3-Series (E36) 4 04-25-2004 10:34 PM
