| Diff Question Hi guys
Im wanting to put a LSD portion from an E36 diff into an E34 diff casing. I know this will work as the gear sets are both type 188.
Just wanting to know which spacer rings set i should use...
because you get two different sizes
SPACER RINGS SET 1,45MM-1,69MM 33139065734
SPACER RINGS SET 1,72MM-1,96MM 33139065735 |
