Dashboard problems - BMW Forum - BimmerWerkz.com
Old 06-15-2004, 08:20 AM   #1 (permalink)
and
and is an unknown quantity at this point
Hi I have 93' 525tds
A week ago the dashboard suddenly swiched off(nothing was working on the dashbord but the car was going well) and after some time it swiched on. It repeats more and more. My dashboard always calculated the distance in kilometres. I noticed that the meter is calculating the distance in miles.
Is there a possibility to make the dashboard calculate in kilometres ?
Thanks.
and is offline   Reply With Quote
Old 06-15-2004, 10:41 AM   #2 (permalink)
frank3 is an unknown quantity at this point
I think your first priority is to fix the dashboard electrical problem. Only then should you tackle to mi/km issue...because if it keeps shorting out, it will keep defaulting back to the mi. readout mode.
Sounds like there's a short somewhere in the wiring harness or connection to the instrument panel. Might want to check the connections at the fuse box first (easiest to find and fix).
<span style='color:green'>1994 325i </span>- - - 75,000 mi.
No mods - - - very happy as is!
<span style='color:green'>1995 525i </span>- - - 154,000 mi.
No squeaks or rattles... unreal!
frank3 is offline   Reply With Quote
Old 06-17-2004, 03:42 AM   #3 (permalink)
and
Fuse box is OK.
I don't know how to turn on kilometres instead of miles. It must be such a possibility.
Maybe someone could give me some advice?
Old 06-17-2004, 10:26 AM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
Don't do this unless you feel you can do it yourself.http://www.bmwe34.net/e34main/maintenance/.../capacitors.htm
It is probably capacitors and the coding chip inside the dashboard. It will cost you like 10 dollars if you do it yourself. Not recommended unless you are fairly good at soldering and if you dont feel comfortable removing the airbag.
how to remove airbag:
http://www.bimmernut.com/~billr/images/air...agAndBulbs.html
Disclaimer: Neither I nor the websites listed above can be held responsible if you screw something up. If you don't feel comfortable doing it, please dont.
Climate Control Problems black318 3-Series (E36) 0 02-24-2005 02:00 AM
Problems With My '99 318i Se... Renwaldo 3-Series (E46, E90) 8 01-07-2005 08:52 AM
94 325is Problems sre2114 3-Series (E36) 23 10-21-2004 04:27 PM
