crazy e34 rattle - BMW Forum - BimmerWerkz.com
Old 09-15-2003, 01:10 AM   #1 (permalink)
hello all
i have a 1990 525i and it seems like whenever i go over a big bump i hear a loud bang or rattle and it sounds like its coming from my trunk or under the car in the back (and its even louder in the backseats) - only , theres nothing in my trunk...
it sounds pretty loud and im totally stumped as to what it is... does anyone have any ideas of what this could be?
Old 09-15-2003, 09:22 AM   #2 (permalink)
SoonerE39's Avatar
SoonerE39 is an unknown quantity at this point
Send a message via AIM to SoonerE39
Did you look in the spare tire well area? Mabye the spare isn't secured or something has slipped under the spare that is bouncing around. I had a golf ball in there that was driving me nuts.
[CODE]<EMBED src="http://members.cox.net/toakes2/Copy%20(2)%20of%20toms%20sig.swf"quality=high bgcolor=#000000 WIDTH=420 HEIGHT=220 TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/...</EMBED>
Sig by Woobiee
<img src='http://www.ousooners.net/Avatars/Tx_Smack/lh_rip.gif' border='0' alt='user posted image' />
1999 528i 5 Speed, Sport Package, Confortti Software, Racing Dynamics Front Lip Spoiler and Rear Apron, Supersprint Muffler, Angel Eyes Upgrade.
SoonerE39 is offline   Reply With Quote
Old 09-15-2003, 08:48 PM   #3 (permalink)
k. thanks for the advice...
so i checked it, its tight.... nothing in there at all... Man this is crazy... and whats worse is its not all the time. grrrr...
anymore suggestions?
thanks again
Old 09-15-2003, 09:03 PM   #4 (permalink)
Ski
Sheer Driving Pleasure
Ski's Avatar
Ski is an unknown quantity at this point
My pal Furious had some good points on this thread..
http://www.bmw-forums.com/forum/index.php?...p?showtopic=685
My Jet Black's
'03 3.0i Z4 Loaded
'02 325Ci Loaded
'06 330xi Loaded
Ski is offline   Reply With Quote
Old 09-16-2003, 03:44 PM   #5 (permalink)
540Iam is an unknown quantity at this point
i had a similar rattle coming from the rear left tire. come to find out it as missing the caliper springs. there should be two of them, a left and a right. my vehicle had none. my mechanic said that there is no problem if you drive without the springs, just get them put on when you replace your brake pads.
540Iam is offline   Reply With Quote
Old 09-16-2003, 10:32 PM   #6 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
Sporky, did you check your muffler/exhaust fittings under the car? Rubber bushes/mounts could be broken or missing causing them to be loose and hit against the undercarriage.
Old 09-17-2003, 12:05 PM   #7 (permalink)
thanks for that bit of info CosmosBlack, i just got in from checking that out. Everything *looks* ok and if i push on it or bang on it i hear a few squeeks and small rattles , but i dont think there was anything loose enough to be making what im hearing. thanks for the suggestion though
Old 09-22-2003, 09:18 AM   #8 (permalink)
yewcorner is an unknown quantity at this point
Hi, I have an E34 M5 which had a similar sought of problem. After much investigation of suspension, I pulled the whole of the carpet out from the boot, only to find what I can only describe as a 'storage compartment'. In this were two spare vehicle jacks, and these had been making all the noise? Check it out?
yewcorner is offline   Reply With Quote
FS E34 Reiger Ground Effects (Full Kit) Gypsysteel Aftermarket Parts 0 11-01-2005 09:09 PM
Question regarding E34 front carpets m3driver97 5-Series (E12,E28, E34, E39, E60) 0 10-13-2005 02:32 PM
Rattle From Rear Brakes Bigron 5-Series (E12,E28, E34, E39, E60) 3 05-16-2005 12:20 PM
05 325i Trunk Rattle Noise sudoloop 3-Series (E46, E90) 6 03-14-2005 03:47 PM
Rear Brake Rattle on 323 Conv. silvox 3-Series (E36) 4 07-07-2004 01:20 AM
