Cracked Center Console on my 540i - BMW Forum - BimmerWerkz.com
Old 08-31-2004, 02:59 PM   #1 (permalink)
LetsPlayPDX is an unknown quantity at this point
I have a 1998 540i and the simulated wood that is around the gear selector on the center console has a crack in it and keeps getting larger. I have not spent much time investigating at this point, but am wondering where to get a new part and then also any info on how to pull the center console apart. I cant tell if the simulated wood piece is an insert, of if it is one large piece and I would have to replace the entire center console.
Any Thoughts?
Thanks
LetsPlayPDX is offline   Reply With Quote
Old 08-31-2004, 08:01 PM   #2 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
Hey man. i just did the exact repair your talking about.
PS (its not a plastic piece, its actual wood, with lamination)
See my "center console piece replaced" post for the results
Unfortunatley, you wont get a perfect match for the wood grain, but it'll still give a very nice appearance.
The part you need to replace is around 150-170 bucks from a dealer...its a dealer only type thing.
take a flathead screwdriver and pry up the "front" (being the section towards the front of the car). there are two retention clips in the rear, the piece will come out easily at this point.
You do need to remove the shift knob as well to do this. It's an easy replacement. save all screws and parts from the old piece as you will need to reuse them. if something like a bulb is bothering you, now would be a good time to replace that as well. Also, give the shifter area a decent cleaning before you install the new part, it gets mad dirty down there.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 09-01-2004, 10:01 AM   #3 (permalink)
Sweeeeeeeeeeeeet!
Thanks for the reply and your other post, this is just what I needed.
Old 09-01-2004, 08:49 PM   #4 (permalink)
glad to help
Old 09-02-2004, 03:26 AM   #5 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
Or...for an easy fix and a change...
you could get one of those carbon fiber pieces with stick-on adhesive
where you just stick onto the current wooden piece. They're on ebay and are inexpensive, only thing is it might not match the rest of the wood interior.
Old 09-03-2004, 03:54 PM   #6 (permalink)
yeah, but CF doesnt go with bimmers usually...
540i bumper center insert wanted jazzbass 5-Series (E12,E28, E34, E39, E60) 2 10-04-2005 05:43 PM
What's A "later Style Center Console Frame"? frank3 3-Series (E36) 2 04-20-2005 01:24 PM
Center Console Jammed Shut dclaw 3-Series (E46, E90) 0 04-19-2005 03:10 AM
Center Console Lights onebadass 3-Series (E36) 2 04-14-2005 12:39 PM
Cracked center console netwrk2 1,6,7,8 - Series and Mini Cooper 0 10-26-2003 10:13 PM
