A couple of evasive issues - BMW Forum - BimmerWerkz.com
Old 04-06-2007, 11:55 PM   #1 (permalink)
e39 5ive is on a distinguished road
Send a message via MSN to e39 5ive
Well here it goes. Just got my car back from a second mechanic, as I refused to believe the first mechanic when he told me nothing was wrong with my car. The second mechanic can't find the source of my problems either. Here are the issues I'm having:
1. This is the one that really annoys me. Car has a vibration/grumble sound @ 40mph. Seems to decelerate quikly, almost feels restricted too. No vibration in the steering wheel, but around my foot area. No one has been able to tell me why. Flex disc, u joints, and driveshaft all seem to be totally fine. Originally thought it was my struts, as they were in need of replacement. However after installation of a set of Bilstien all around, the noise and vibration remained. I run a set of staggered wheels 18x8.5 front, 18x10 rear, but even with the stock wheels and good tires the problem stays.
2. My mpg gauge is on some type of delay. I press the gas and the needle takes a second and then pins itself at 8mpg as if I'm gunning it. As the car changes gears the delay remains ultimately settling at the 25 - 28mpg range at normal highway speeds 70 or so.
This time around, I might add, the second mechanic told me I have an oil cooler leak. So that's something I'll be adressing soon.
I've been checking in on a couple of previous posts, and have also checked through archives, all seem to be dead ends. Or at least I've found no answers. Hopefully someone can help me out.
Much appreciated,
E39 5ive
e39 5ive is offline   Reply With Quote
Old 04-07-2007, 11:14 PM   #2 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
auto or manual? and whens the last time youve changed your tranny fluid and rear diff fluid?
Old 04-08-2007, 12:04 AM   #3 (permalink)
Auto, and I've done neither services. 108,000 miles.
Old 04-09-2007, 09:40 AM   #4 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Do you experience the same vibration when the car is running in "park" and step on the gas? Or is it only when it's moving?
Have seen any leaks coming from your differential? Does it look wet/oily in that area?
You said you looked at the drive shaft, did they tighten the bolts to proper torque? These bolts are known to come loose!
to answer your questions above...
My 540i decelerates quickly as well. This is normal on V8's with an auto transmission. The vibration part, not normal
The needle comment you had is also normal, is not a problem.
LOS
Old 04-09-2007, 10:37 PM   #5 (permalink)
ozarkmark's Avatar
ozarkmark is an unknown quantity at this point
1. This is the one that really annoys me. Car has a vibration/grumble sound @ 40mph. Seems to decelerate quikly, almost feels restricted too. No vibration in the steering wheel, but around my foot area. No one has been able to tell me why. Flex disc, u joints, and driveshaft all seem to be totally...
That is exactly what I am experiencing so I replaced the front left bearing to no avail. It would get louder if I turned to the right therefore I thought a bad bearing was the issue.
I will probably take it to my mechanic soon and will keep you posted.
1998 528i - sold 222,000 miles
1998 540i - sold 159,000 miles
2007 328i Coupe - 30,000 current
ozarkmark is offline   Reply With Quote
2003 M3 Battery issues samdog07M32003 New Members Check In 0 01-01-2007 12:35 PM
Fuel issues? Car bogging! ReaverJam 3-Series (E21, E30) 5 10-04-2005 10:16 PM
Just Bought My First Bmw, Some Issues :( chindian 3-Series (E21, E30) 2 03-25-2005 03:30 PM
1992 525i Help Fixing Electrical Issues gregruby 5-Series (E12,E28, E34, E39, E60) 1 03-05-2005 11:37 AM
Electrical Issues fireblade97rr 5-Series (E12,E28, E34, E39, E60) 5 10-17-2004 03:48 PM
