Cooling fluid change: Bleed the system? - BMW Forum - BimmerWerkz.com
Old 07-15-2006, 05:47 AM   #1 (permalink)
JMVPMD is on a distinguished road
I would like to know if is necessary to bleed the system when you replace the cooling fluid. If so, which is the way of doing so. Thanks. JM
JMVPMD is offline   Reply With Quote
Old 07-15-2006, 06:56 AM   #2 (permalink)
da_administrator
da_bull's Avatar
If you have an E34, check this out: http://www.bmwe34.net/e34main/mainte...eplacement.htm
On my car, you will have to bleed it quite a few times to get all the air out. Just be patient and it'll work.
Old 07-15-2006, 04:03 PM   #3 (permalink)
cnn
cnn is on a distinguished road
Here you go
I did the cooling system and did the write-up here:
http://bimmerboard.com/forums/posts/199986
HTH
cn
98 528i
cnn is offline   Reply With Quote
Old 07-16-2006, 08:27 AM   #4 (permalink)
Actually my car is a 523i -E39-
Old 07-16-2006, 03:00 PM   #5 (permalink)
325isBaby's Avatar
Car: 2005 330xi
you will find a plastic philips headed screw either on the overflow tank or around the upper radiator hose..that's where you bleed the system
Come see me at MySpace
Old 07-16-2006, 08:07 PM   #6 (permalink)
Eric S.'s Avatar
Eric S. is on a distinguished road
There will be a drain bolt on your engine block that you should remove as well, in order to thoroughly drain your coolant. The aluminum washer should be replaced, but don't sweat it if you cannot find a replacement washer, just re-use the old one.
<span style='colorurple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline   Reply With Quote
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
$8.00 Power Steering Fluid Change acoustic 3-Series (E36) 0 05-18-2006 01:11 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
When to change "lifetime" tranny fluid LloydM 3-Series (E36) 9 08-31-2004 03:38 PM
