Coolate Temperature Sensor? - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 12-11-2009, 09:32 PM Thread Starter
Larry in Mesa is on a distinguished road
I have a 2001 530i. Can anyone tell me where the Coolant Temperature Sensor is located. I have the part, ordered from Bav Auto and can not find this sensor location.
Thank you for your help.
Larry
Larry in Mesa
2001 530i Dinen
Larry in Mesa is offline
post #2 of 10 (permalink) Old 12-11-2009, 10:43 PM
42, The meaning of life
brettski's Avatar
brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice
Have a look at RealOEM.com Online BMW Parts Catalog it won't show you how to get to it, but it might give you an idea about where its positioned relative to other more identifiable parts.
brettski is offline
post #3 of 10 (permalink) Old 12-13-2009, 05:19 PM Thread Starter
Thanks
Thank you for the help. I am not much of a Bimmer mechanic. I let you know what I find.
Larry
Larry in Mesa
2001 530i Dinen
post #4 of 10 (permalink) Old 12-13-2009, 06:09 PM
Ich bin der Modifikator
johnnyBgood's Avatar
johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough johnnyBgood is a jewel in the rough
Maybe # 4 in link below:
lower radiator hose
RealOEM.com BMW E39 530i Cooling System Water Hoses
jb
____________________________________________
johnnyBgood is offline
post #5 of 10 (permalink) Old 12-13-2009, 06:20 PM Thread Starter
Thank you, again. You have helped me in the past and it is great that you are able to help me again, now.
Have a great holiday.
Larry
Larry in Mesa
2001 530i Dinen
post #6 of 10 (permalink) Old 12-13-2009, 06:23 PM
Larry
You are Welcome........Happy Holidays!
jb
post #7 of 10 (permalink) Old 01-11-2010, 08:47 PM
Poolman is on a distinguished road
There is another coolent temp sensor--the one thats used by the ecu to feed it infor is located at the back of the engine--under the intake manifold--it's hard to get to.
You will need to remove the cabin air filter and duct work on the drivers side and then you will need a mirror and a flashlight to find the temps sensor--it sets high under the intake back there. While back there you should also check the vac hose's that are there also, feel them around a little--if your hand looks black afterwards you need to change them for new one's--these hose's break and cause all sorts of vacuum problems--people miss these because they can't readily see them.
Poolman is offline
post #8 of 10 (permalink) Old 01-13-2010, 06:28 PM Thread Starter
Thanks.
That is the sensor and I was able to replace it. It is almost like they were trying to hide the thing. Thank you for your post. After 10 months of the car on jack stands, it is back on the road. Next month, it is the brakes!
Larry
Larry in Mesa
2001 530i Dinen
post #9 of 10 (permalink) Old 01-13-2010, 07:36 PM
Glad to be of help Larry--hope it all works out for you---if you don't mind would you
try and discribe what you went through in replacing that sensor. Were you able to remove and replace the sensor without removing the intake manifold?
Poolman is offline
post #10 of 10 (permalink) Old 01-13-2010, 07:48 PM Thread Starter
It was not too bad, once you found the thing. When I removed the climate control assembly vent, it made a big diffence in access. I did break off one side of the clip where the wires plug into the sensor (tough to get the clip off). Also, the old sensor and the new sensor were differnet mm sizes. The old was 20mm and the new was 17mm. I lost some fluid, but not bad. The only taht worried me was bleeding the system of any air after I replaced the sensor. I had the front up on jack stands because I was replacing the radiator. So, I did a normal bleed while it was in the air and have not had any problems.
Hope that I have helped!
Larry
Larry in Mesa
2001 530i Dinen
Outside Air Temperature Sensor kohlers 3-Series (E46, E90) 10 08-29-2009 09:38 PM
Ambiant Temperature Sensor mrmojo37 5-Series (E12,E28, E34, E39, E60) 2 01-22-2009 04:58 PM
Ambient Temperature Sensor Tacorom6969 3-Series (E36) 7 07-17-2005 02:42 PM
Temperature Sensor bimmer joe 3-Series (E21, E30) 2 07-19-2004 06:24 PM
Temperature Sensor CaptainEL 5-Series (E12,E28, E34, E39, E60) 7 01-15-2004 01:23 AM
