Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 12-15-2003, 02:28 AM   #1 (permalink)
Photos: 0
bccwu is an unknown quantity at this point
Hi, I would like to get some opinions on this small issue. Recently the LCD indicator started giving me the warning about "checking coolant level". So I checked and it's almost empy. So I called the service dept. of the local BMW dealership. The guy told me I need to bring it in and do a total coolant flush. This car has really really low mileage : about 20K KM or 13K Miles. I hardly drove it for the last 10 months. My question is : Can I simply do a coolant refill or the guy just wanted my money?
Thanks, Bill
bccwu is offline   Reply With Quote
Old 12-15-2003, 04:23 AM   #2 (permalink)
SoonerE39's Avatar
Photos: 0
SoonerE39 is an unknown quantity at this point
Send a message via AIM to SoonerE39
Normally a radiator flush is done around 60,000 miles. I don't see a problem with just filling it and avoiding the flush with your mileage that low.
[code]<EMBED src="http://members.cox.net/toakes2/Copy%20(2)%20of%20toms%20sig.swf"quality=high bgcolor=#000000 WIDTH=420 HEIGHT=220 TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/...</EMBED>
Sig by Woobiee
<img src='http://www.ousooners.net/Avatars/Tx_Smack/lh_rip.gif' border='0' alt='user posted image' />
1999 528i 5 Speed, Sport Package, Confortti Software, Racing Dynamics Front Lip Spoiler and Rear Apron, Supersprint Muffler, Angel Eyes Upgrade.
SoonerE39 is offline   Reply With Quote
Old 12-15-2003, 04:45 AM   #3 (permalink)
Photos: 0
Chooch is an unknown quantity at this point
fill it and do a pressure test of the coolant system .... you can get the kits, i think, at auto supply stores ... you may have a busted hose or worse a crack in the engine block ... i really don't think it's normal to be that low on coolant ... maybe the thermo is shot and the coolant is boiling over ....
<span style='color:blue'><span style='font-family:Arial'>If I try to be like everyone else, who's going to try and be like me?</span></span>
<span style='color:blue'><span style='font-family:Arial'>Mi casa no es su casa, hijo de puta.</span></span>
Chooch is offline   Reply With Quote
Old 12-15-2003, 01:30 PM   #4 (permalink)
EXtech's Avatar
Photos: 0
don't get all freaked out about a cracked block or anything. Fill the system and then pressure test it. Don't do a flush, you don't need it yet. There used to be a radiator cap recall on alot of the cars do to coolant loss from improper sealing. I would go through a pressure testing of the system and determine if there are any leaks. If the car has any warranty, then let the dealer do it and make sure they do an extended test on it where they leave the system pressurized for at least 20 minutes ( and not completely cold). From the sounds of it, I would take it to a different place than the one that told you to flush the system. It will be very expensive to go buy the tester itself because after you spend $60-100 or more for the tester, then you have to buy a special adapter for the beemers and those cost 20-30 bucks. After you've covered the basics, then start focusing on more complex issues.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-16-2003, 01:33 AM   #5 (permalink)
Photos: 0
Thanks for these helpful advices. Yesterday after work, after reading your advices, I went to the dealership trying to get some genuine BMW coolant, but the guy told me it was just generic aluminum compatible antifreeze they sold. So I bought some from a local Canadian Tire (like Kmart in the States) instead. I tested the colour of the remaining coolant in my car and it was very green so there was no dirt in it.
I then mixed 2 L (1/2 GAL) of the bottled coolant 50:50 with some spring water (the purest I could get from a grocery store). I proceeded to fill it up in the car. The coolant indicator popped up after less than 300ML (0.08 Gal) or so of the mixture added! I put the cap back and start the engine. The warning disappeared!
questions :
1) Could I have a faulty coolant level sensor?
2) can I store away the remaining 1/2 GAL non-mixed coolant and the already mixed (with water) coolant for future use? I put them in the unheated garage, but it's like -15C (5 F) outside)
3) if I proceed to do a pressure test, can I just go to any hardware store and pick up a pressure test kit? Where can I get the special adoptor the last poster suggsted?
Thanks again, Bill
Old 12-16-2003, 03:44 AM   #6 (permalink)
EXtech's Avatar
Photos: 0
It doesn't take much to set off the low coolant sensor in these cars. If the level dropped below where you could see it then it was probably low enough to trip the light. If it was only that low, I would suspect that you've got a huge leak or anything but if you want to still test the system then you can find the adapter at any major tool supplier like Snap On, MAC Tools, Matco Tools, Stahl Wille, Cornwell. I know a Stahl Wille toolman here in Texas who is the best guy in the world. If you want, I can put you in touch with him. He has awesome prices and usually will work deals not to mention he has access to any tool that you want. The good thing about Stahl Wille is that they specialize in German auto maker tools (ie. for BMW, Mercedes....). PM me if you are interested. Hell, if anyone else is interested then PM me also.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 12-16-2003, 03:49 AM   #7 (permalink)
EXtech's Avatar
Photos: 0
..the more that I think about it, if there is something that is wanted by the masses then he would surely make a group discount. He has pressure testers to brake bleeders to specialty wrenches to service indicator reset tools.. everything you can't find anywhere else.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 12-16-2003, 05:51 AM   #8 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
Photos: 0
bccwu,
My advice from personal experience with two 540i radiators, is to check around the plastic "neck" area on top right (when you're standing in front of the car facing radiator) of the radiator. That is a common problem with fine hair-line cracks, which you wouldn't even notice normally. Also, on the 2000 540's, the upper assembly hoses for the radiator, where it goes into the engine, they need to be replaced. It's in the service bulletin. If you check them out and see greenish deposits around the joints, that's one of the possible causes of a leak. The updated replacement is a simpler setup and has less joints.
Good luck!
vB code is On
00' 540i Coolant Spooting Out Of Screw? Greg T 5-Series (E12,E28, E34, E39, E60) 3 05-20-2005 08:43 AM
2000 E39 Central Lock Problem rsacho 5-Series (E12,E28, E34, E39, E60) 1 04-24-2005 03:01 PM
E34 525i Coolant Problem rml612 5-Series (E12,E28, E34, E39, E60) 3 01-25-2005 06:57 PM
2000 Bmw 323ci Transmission Problem Max24 3-Series (E46, E90) 3 01-07-2005 04:50 PM
Problem with the Coolant Leak RedBeemer95 3-Series (E36) 3 07-23-2004 03:53 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
