Coolant on the ground and a weird haze... - BMW Forum - BimmerWerkz.com
post #1 of 13 (permalink) Old 01-21-2004, 04:14 PM Thread Starter
dubumb's Avatar
dubumb is an unknown quantity at this point
Send a message via AIM to dubumb
This is a new problem...
I had an oil leak for awhile but i got "OIL STOP LEAK" or something and it's virtually stopped. Now i go outside and see coolant on the ground. I just got a new radiator so i know it's not that..... And no today i went to the store and saw a VERY VERY VERY Faint while haze... like fog coming outa my heat/ac vents it only lasted like 2-5 seconds and i cranked on the heat too see if anymore would come out... None did and the heat worked fine... As i was out the car DID NOT overheated. Can anyone help me? it seems like one thing after another with this car...
<center>
<img src='
<a href='
target='_blank'>my car @ cardomain....</a>
<a href='
target='_blank'><img src='
border='0' alt='user posted image' /></a>
&lt;/center&gt;
dubumb is offline
post #2 of 13 (permalink) Old 01-21-2004, 07:58 PM
TECH's Avatar
Is the coolant leak a big leak, or a small. What part of the car is it coming from, front or back?
Which car/engine do you have?
TECH is offline
post #3 of 13 (permalink) Old 01-21-2004, 08:11 PM Thread Starter
dubumb's Avatar
It's coming from the front... it's a small leak... 92 525i (e34)
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #4 of 13 (permalink) Old 01-21-2004, 08:13 PM Thread Starter
dubumb's Avatar
m50 24v
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #5 of 13 (permalink) Old 01-21-2004, 10:49 PM
TECH's Avatar
If it was the heater core, it would drip out of the ac drains, which would be at about the foot pedal position. If it's closer to the front, its gotta be something else.
Fill the coolant, run the engine and let it get hot. This will pressurize the cooling system, which will make finding a leak easier.
Grab the engine fan with the engine off, and see if there is any play in the pump-even if there isn't, it may still be leaking. A good flashlite and a mirror are good for seeing the small out of the way places.
TECH is offline
post #6 of 13 (permalink) Old 01-22-2004, 01:27 PM Thread Starter
dubumb's Avatar
UPDATE: i went out this morning and there was nothing on the ground... BUT when i was driving the haze coming from my heater vents was still there (only like the first 5 min i was driving though)
what could this be?
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #7 of 13 (permalink) Old 01-22-2004, 02:41 PM
KingScare's Avatar
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
stoners in your dashboard...
KingScare is offline
post #8 of 13 (permalink) Old 01-22-2004, 06:28 PM Thread Starter
dubumb's Avatar
:P
Anyway... does anyone know what could be wrong?
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #9 of 13 (permalink) Old 01-22-2004, 09:56 PM
EXtech's Avatar
I know this might sound dumb but what does the air from your vents smell like? (not pot smoke king scare) Where do you live? Has the a/c been serviced recently? and Is there any condensation around the vents?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to
and register.. it's FREE
EXtech is offline
post #10 of 13 (permalink) Old 01-23-2004, 09:40 AM Thread Starter
dubumb's Avatar
No condensation... and the haze smells like coolant...
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #11 of 13 (permalink) Old 01-24-2004, 10:21 AM Thread Starter
dubumb's Avatar
bump
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #12 of 13 (permalink) Old 01-24-2004, 12:25 PM Thread Starter
dubumb's Avatar
I need to know if this is a big problem soon... I am planning on taking a 400 mile trip in mid february so i would need to have it serviced/fixed be4 then if it's a big problem... Thanks!!!
&lt;center&gt;
<img src='
<a href='
<a href='
&lt;/center&gt;
dubumb is offline
post #13 of 13 (permalink) Old 01-24-2004, 03:43 PM
TECH's Avatar
It would be best to pressure test the system. Find the leak, if it has one. Any leak can develop into a problem.
TECH is offline
Ground Clearance On M3 cpadpl M-Series (M1, M3, M5, M6) 4 03-29-2005 06:44 PM
Where Is The Radio Ground At? d92782 3-Series (E36) 4 03-09-2005 03:24 PM
Where'd The Coolant Go? Linds 3-Series (E36) 1 11-17-2004 03:41 PM
